Clamping jig for glue ups
Forum topic by RussellAP posted 12-22-2012 08:48 PM 1442 views 0 times favorited 4 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3103 posts in 2158 days
12-22-2012 08:48 PM
Imagine a cast iron box.
This box has adjustment wheels like a table saw so you can increase the length and the width of the box.
Further imagine that there is a fixed bottom to this box.
So you have a cast iron box, which measures roughly 20”x 6”x24”deep.
It’s adjustable so the box and be made to fit whatever glueup you have.
Then for the to of the box, you have a bar which is attached to two or three more wheels that you can use to crank down on the boards inside the cast iron box.
Glue wont stick to cast iron.
The box is perfect so all you do is crank the box down to fit the size of the glue-up. and you put pressure from the top evenly and you can get much more pressure.
You can make the interior of the box with little ridges to allow for air flow and have 1” holes in the cast iron to keep air circulating around the boards.
Tell me why some tool company hasn’t done this yet?
9763 posts in 3519 days
#1 posted 12-22-2012 08:54 PM
Are you talking about a drawer or case clamp? I have
a drawer clamp. It’s pretty cool. It’s very heavy
and would have been quite costly when new.
RussellAP
#2 posted 12-22-2012 09:05 PM
Loren, something that would have it’s own stand. It would look like a jointer. bottom would be flat cast iron with ridges and holes for air flow, the back would be 7” cast iron, like a fence. The sides would also be 7” by 24” with an attachment point for the top which is where you put the pressure on the boards after you glue them and put them in the box. Then all you do is put the top on and crank down and let dry. It would make a perfectly straight glue up, unless the boards warp afterward.
View George_SA's profile
George_SA
342 posts in 2085 days
#3 posted 12-22-2012 09:14 PM
The problem is that it will be very expensive and woodworkers being what they are will build their own jigs simulating the jig and the tool company will not make any money from it :-)
-- There are some things that money can't buy - Manners, morals and integrity
View patcollins's profile
patcollins
1620 posts in 2737 days
#4 posted 12-22-2012 09:18 PM
That would be really really heavy too.
