Finishing Cherry
Forum topic by RussellAP posted 12-22-2012 03:41 AM 1626 views 1 time favorited 24 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2460 days
12-22-2012 03:41 AM
I’m building a chest from cherry. Some of the wood is lighter, not sapwood but just a lighter shade.
My question is, would you stain the chest the same color as the darker wood or would you just finish it out with some poly as is. It’s a pretty good match grain-wise, but the color is noticeably different.
If I did stain it to match, I’d likely give it a couple coats of Charles Neil conditioner to keep the blotch down and also to keep the stain light.
24 replies so far
View BentheViking's profile
BentheViking
1782 posts in 2737 days
#1 posted 12-22-2012 04:02 AM
what percentage is off colored? can you use it on the backside or bottom of the chest? I’d recommend doing what you can do to utilize what you’ve got. If there is no way then I’d stain it, but then the questions is how dark
-- It's made of wood. Real sturdy.--Chubbs Peterson
RussellAP
#2 posted 12-22-2012 04:05 AM
I think I need to get it in some good light and wipe some denatured alcohol on it and see if I need to do anything first. I don’t like staining, this wood is beautiful the way it is and after some poly and 1200grit I think it will look outstanding.
View NiteWalker's profile
NiteWalker
2738 posts in 2750 days
#3 posted 12-22-2012 04:21 AM
No stain, the color will even out over time.
117273 posts in 3750 days
#4 posted 12-22-2012 04:30 AM
Russ
You can either use only the wood that matches or use some dye stain on it to blend it together after a couple coats of Charles Blotch control. I’ve never heard of anyone using 1200 grit on wood other than to buff out the clear top coat for a high gloss clear.
View Don W's profile
Don W
18988 posts in 2741 days
#5 posted 12-22-2012 12:54 PM
Use the contrast in the design. I love the contrasting woods in a project. It adds character and focal points of the design.
View Monte Pittman's profile
Monte Pittman
29962 posts in 2511 days
#6 posted 12-22-2012 12:59 PM
I would probably leave it as well.
View CharlesNeil's profile
CharlesNeil
2453 posts in 4044 days
#7 posted 12-22-2012 02:29 PM
my .02 is what I do on all cherry, I do not like the mismatched colors unless i intend it to be so. To me it just looks what it is, mismatched, and I have tried to let it age, and sorry to disagree, if its lighter now it will always be lighter. However often it can be a simple case of one piece being planed a little more than the other. Cherry darkens as it ages, even if unplaned, and depending on how deep you go when planing, or how long the material has been sawn, can also make a difference. Meaning a piece of cherry that has been sawn for 2 years , VS one sawn 1 year , you can get a varience in color. The other issue is where it came from, meaning, trees like anything else can vary depending on the soil it grew in. The thing that determins the color is the amount of tannins . All of this said, I just cant afford to risk it, so dye all my cherry , and most of my cherry is ” Natural” cherry, so I select the closest color match i can get, , then I dye it to a color that matches approx 3 year old cherry, and let mother nature take it from there. Has been my MO for many many years.
View tyskkvinna's profile
tyskkvinna
1310 posts in 3159 days
#8 posted 12-22-2012 03:26 PM
I would also leave it… and if you are giving it to somebody, explain that over time the whole piece will darken rather significantly. IMO that’s the best part of cherry.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
RussellAP
#9 posted 12-22-2012 03:55 PM
Charles, this had been sitting for over three years. I got it from a guy that does flooring from scratch, mostly white oak. He had bought the cherry for a special order that never happened. The boards had green and blue ends which means it’s already planed and jointed on all sides. I did sand if from 40g to 240g to remove some of that patina and some scratches and gouges. It didn’t need to be planed.
I’ll grab a couple boards and see if I can match them with some dye.
How many coats of conditioner should I use, I was thinking two?
BentheViking
#10 posted 12-22-2012 05:06 PM
Someone came into my store last week with stained cherry cabinet samples. The raw material was really far off in color and when they added stain to it it almost looked like ipe with the hard contrast of the light and dark. terrible and distracting. That being said I to enjoy color variation when it is done right and done intentionally.
CharlesNeil
#11 posted 12-22-2012 05:18 PM
Russell , do 2 prestain , I use 1 part General Finishes cinnamon dye , to 1 part light brown (GF) and 1 part water , season to taste, meaning add more cinnamon for more red, and brown, for brown,
I have a nice 3 board cherry table I made about 5 years ago,(no dye) I added a 1/2 part more of the cinnamon, and it matches perfectly, and the color is even. As the cherry ages it will mellow and take over past the dye, that said, the natural look is not lost, its just evened out. My clients dont seem to like mismatched pieces. Additionally if they buy other pieces, using this formula, they match, I like that and so do they. the above formula is for a natural cherry color *
#12 posted 12-22-2012 05:47 PM
Wow Russ where else can you go to get finishing advise from a expert at no charge.Charles has a new finishing book coming out,I know it will be a great investment for all woodworkers and even more so for those who are devolping a woodworking business.
Thanks Charles I was looking for that formula this morning .
RussellAP
#13 posted 12-22-2012 08:22 PM
thanks Charles. I have it saved for when I get to that point. I have more time than I figured because my son won’t be making it over for Christmas and it’s his present.
This means I can relax and take my time.
I just wish there was a place to get General Finishes around here close by.
View waho6o9's profile
waho6o9
8480 posts in 2750 days
#14 posted 12-22-2012 08:30 PM
I think it would be best to leave it alone.
A lot of great friendly advice to absorb as well.
CharlesNeil
#15 posted 12-22-2012 09:09 PM
Whatever floats your boat folks, whatever floats your boat!
