| Forum topic by LearningAsIGo | posted 154 days ago | 538 views | 0 times favorited | 9 replies | ![]() |
154 days ago |
I need to prime and paint some boards that have knots in them. I’m using dark paint, so I’m not sure if you will be able to tell if the knots bleed through? Through googling I have seen that the general consensus seems to be that in order to seal knots you need to use BIN primer or else they will bleed through. I have definitely seen this with latex primer. Will knots bleed through oil based primer or can you use oil to seal them also? |
9 replies so far
#1 posted 154 days ago |
Use Zissner’s Seal Coat. -- Jerry |
#2 posted 154 days ago |
The BIN Primer is just dewaxed shellac, either clear or pigmented white. There are oil-based and latex primers out there, Kilz being one I have in stock. Rustoleum (Zinsser) also has water and oil-based variants. The BIN primer will work regardless of the top-coat as shellac is universal in what can go on top of it, though I would typically use a water-based primer with a latex finish, like the aforementioned Kilz or the Rustoleum alternatives. However shellac is a better barrier than the other alternatives, so if you are priming to cover nasty odors or something, then I’d use the shellac-based BIN. Likewise, for your application, I’d stick with shellac…it’s slightly better as a moisture barrier, but it also dries very fast…giving really runny knots little chance of affecting the primer as it dries (which could be a problem with the slow drying oil-based stuff). The Zinsser Seal Coat mentioned by Jerry is essentially the same stuff as the BIN Primer, perhaps a little thinner than the Bin Primer (though that’s just a guess on my part), and clear like typical shellac. -- jay, www.allaboutastro.com |
#3 posted 154 days ago |
Try Putting some super glue on them. That will seal them and also keep them in place if they are loose. -- Thor and Odin are the greatest of Gods. |
#4 posted 154 days ago |
I have Zinsser 123 latex based primer I have a quarter of a can of bin but it’s been sitting in the basement awhile and I’m not sure if it’s usable. Can I use one of these? |
#5 posted 154 days ago |
+1 more for zinsser BIN. That stuff is amazing. -- He who dies with the most tools... dies with the emptiest wallet. |
#6 posted 154 days ago |
Zinsser Bin is definitely the product to use. Get the Shellac based. The Latex stuff is good for general purpose priming but won’t seal the knots |
#7 posted 154 days ago |
If it was me, I’d seal the knots with epoxy….You didn’t mention the type of wood you’re using, but I’d mix up a little dust with the epoxy and fill them it…..good to go…... -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#8 posted 153 days ago |
The wood is dimensional lumber so probably douglas fir or whatever else they make it out of |
#9 posted 153 days ago |
another ZINSSER b.i.n. here ..pine knots…. shellac based primer two coats an lookin good!!!! -- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA. |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15802 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2844 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
