white areas on the crossgrain
Forum topic by yrob posted 180 days ago 447 views 0 times favorited 13 replies Add to Favorites Watch
View yrob's profile
yrob
271 posts in 1849 days
180 days ago
Topic tags/keywords: question cherry finishing sanding
what are those white areas on the crossgrain of the cherry ?
its typically in the corner. could this be discoloration from the glue ?
this has been sanded to 220 grit.
-- Yves
13 replies so far
View Mark Smith's profile
Mark Smith
382 posts in 236 days
#1 posted 180 days ago
Sap wood. The inner core of the tree is dark and the outter part is lighter. Your board just cuts out into the sap wood.
-- Mark Smith, Tracy, CA., http://www.markscustomwoodcrafts.com
View DS's profile
DS
1848 posts in 617 days
#2 posted 180 days ago
While the sapwood of Cherry IS white and DO I see it crossing the outside corners of the Cherry, there also appears to be white smudges in the photo that looks like glue stains to me. It even appears to smudge across a couple different wood species there if I am seeing it correctly. (Could be light in the camera lens – hard to tell exactly)
End grain is quite porous, so the glue can really go deep. You may be sanding quite a bit to get these out.
View yrob's profile
yrob
#3 posted 180 days ago
Ok. thanks for the feedback. I thought I had selected boards with no sapwood but apparently I must have missed that little bit of sapwood on the side of one cherry board..
Yes, I am going to sand more. That other smudge is probably glue. Each time I glue up a cutting board, I have glue flying everywhere in the heat of the moment of trying to quickly glue up 24 strips. Still have to figure out the optimal way..
-- Yves
View Grandpa's profile
Grandpa
2399 posts in 872 days
#4 posted 180 days ago
Wash it off with a clean wet rag. Wash it a couple of times.
Mark Smith
#5 posted 180 days ago
You may have selected boards with no visible sap wood, but once you cut into them it was there. Look at the walnut cutting board below. I didn’t see the sapwood until I planed the glued up cutting board. It was visible on the other side of the board, but I had done the glue up so one side would be all dark wood, but that didn’t work out.
Grandpa
#6 posted 180 days ago
Yes Mark but look at the photo. The white goes across the joint to the other wood also. This is applied and not sapwood.
Mark Smith
#7 posted 180 days ago
Grandpa, I don’t think those are the white marks he’s talking about. He’s talking about the sapwood in the corners of the cherry pieces.
View DS's profile
DS
#8 posted 180 days ago
Mark, those are some mighty fine Walnut racing stripes in that board of yours! ;-D
Wood has a way of asserting its “natural” charms I suppose.
View RussellAP's profile
RussellAP
2428 posts in 483 days
#9 posted 180 days ago
You might be able to fix that sap wood with a little Gel Stain and a Q-tip. At least make it more defined against the sap wood. I’d tape the sapwood first. The other looks like a bit of glue or something. I’d try a piece of 180 by hand and see if it sands out. Go easy.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
View DS's profile
DS
#10 posted 180 days ago
Yves, you might try gluing up in two stages to help take off some pressure during the glue up.
Half as many strips at a time, then glue two halves together.
There is a practical limit to how much glue one can sling about at a time before joints begin to fail.
I think I am worst when it comes to glue slinging.
View Mark Kornell's profile
Mark Kornell
179 posts in 727 days
#11 posted 179 days ago
Mark, there’s nothing wrong with that cutting board – the sapwood stripes add a ton of character
-- Mark Kornell, Kornell Wood Design
Grandpa
#12 posted 179 days ago
If that is all you are concerned with, then realize you are dealing with wood and that is what makes it wood. Some things you live with.
Mark Smith
#13 posted 179 days ago
Iguana I didn’t mean to imply there was anything wrong with it. It actually sold for a nice price. I was just pointing out to the original poster here that the sap wood only showed up after I planed and sanded the board. He was saying basically the same thing happened to him as the sapwood wasn’t visible when he selected the boards for his cutting board.
