Snipe on short pieces w/ the DW735x
Forum topic by Marcus posted 180 days ago 600 views 0 times favorited 15 replies Add to Favorites Watch
View Marcus's profile
Marcus
550 posts in 216 days
180 days ago
I’ve always been a bit disappointed on the amount of snipe I get on my DW735x even with the extension tables installed. Usually I can put a little upward pressure on the board going in and out of the planer to alleviate most of it. The problem I am having now is that I’ve started planing a few shorter pieces, 18-24” or so it makes it difficult to do the pushing up work around.
Is there some sort of other setup variables I should be looking at that might alleviate snipe that I should look into?
15 replies so far
View PurpLev's profile
PurpLev
7814 posts in 1845 days
#1 posted 180 days ago
unfortunately that’s the physics of the planer, and with shorter pieces you WILL get snipe.
you could work around it by gluing 2 longer strips on both sides of the short board , then running that through the planer. the longer strips will maintain proper contact with the rollers and will control the snipe on the shorter “middle” piece you are planing.
it does take an extra few steps though, but if you are stuck with shorter pieces to work with, this is a good alternative.
View Bill White's profile
Bill White
2649 posts in 2157 days
#2 posted 180 days ago
Use a “slave” board and double sided tape.
I do it a lot with my 733.
Bill
-- bill@magraphics.us
View bandit571's profile
bandit571
3829 posts in 880 days
#3 posted 180 days ago
Start with a”scrap’ board. As soon as the roller starts the board through, start a good board. At the end of each run of good boards, be sure to run another scrap board. That way, all the snipe gets snipped into the scrap.
Marcus
#4 posted 180 days ago
Well, glad to hear I am not alone at least.
A question for you about the slave board Bill. Do you put up pressure on the in/out feed of the board as well? Or is the extra contract w/ the planer bed enough to keep it from tipping and so its planed as if it was the middle of a long board?
View Dallas's profile
Dallas
1933 posts in 684 days
#5 posted 180 days ago
Doesn’t the 735 have a head lock like the Delta 22-580?
I have the Delta and once I lock the head at a given depth there is no snipe.
View joein10asee's profile
joein10asee
1788 posts in 204 days
#6 posted 180 days ago
I have found that if I take TINY cuts, the snipe issue is almost gone. It takes quite a bit longer to get the piece planed, but it seems to be working forme.
And no, the 735 doesnt have the head lock. I belivie it’s the 734 that has it.
View John Ormsby's profile
John Ormsby
1238 posts in 1933 days
#7 posted 180 days ago
I used a brand new 735 all last summer and never had any problems with snipe. I was very please with the planer. It could be the feed rollers are exerting too much pressure and need to lightened up a bit.
-- Oldworld, Fair Oaks, Ca
Marcus
#8 posted 180 days ago
I barely can take more than 1/32 off without getting snipe with my planer. I’ve also had issues with it moving from the set height. Maybe I have a dud.
PurpLev
#9 posted 180 days ago
the 735 doesnt have a headlock because with it’s 4 post design it doesn’t need to lock the head (it’s sort of automatically done by the columns). the problem with the snipe in this case isn’t the cutterhead, but the rollers – since the pieces are short, they are only being supported by 1 of the rollers which tilts the parts into the cutterhead resulting in snipe. this would happen on any other planer as well regardless of how small of a bite you setup the planer to take. the solution is to use buddy-boards that will maintain proper pressure against both rollers (can be glued, tacked, or screwed to your good board, although only gluing will keep it from having left over holes.
the part about your planer moving from set height is an all different issue…
Marcus
#10 posted 180 days ago
I just got off the phone w/ Dewalt. They suggested taking it back and exchange it since its under 90 days old. They were pretty adamant that I had a dud and there is no reason I should be having the issues I have. Great service at least, hopefully the replacement will work out better.
Dallas
#11 posted 180 days ago
Purplev,
The Delta has the 4 post design and when you lock the head the rollers no longer spring up or down, they are locked in place.
That means the tension on the board is equalized on both the top and the bottom so it won’t lift or lower as it goes through.
I often run short pieces 16” or less through with no snipe whatsoever.
View derosa's profile
derosa
1466 posts in 1032 days
#12 posted 180 days ago
if the board isn’t too wide I find sending it through at an angle can help stop the snipe. Not certain why a corner hitting first would get snipe on the corner but it almost never does. Upside is it also seems to reduce tear out on more figured wood.
-- --Rev. Russ in NY-- A posse ad esse
View Sirgreggins's profile
Sirgreggins
232 posts in 432 days
#13 posted 114 days ago
I just got a 735 slightly used and i love it. Especially b/c it’s my first planer. Quick question though: when planing short boards, can’t you use a long piece of scrap and feed that in first, then put your short pieces in while the long scrap is still being fed to reduce snipe?
View DIYaholic's profile (online now)
DIYaholic
7575 posts in 872 days
#14 posted 114 days ago
Sirgreggins,
YES. That is the buddy board someone mentioned earlier. The buddy board should be long enough to engage the rollers during infeed & outfeed of the workpiece.
-- Randy-- I may not be good...but I am slow!
Sirgreggins
#15 posted 114 days ago
sweet. i’m still a newbie to woodworking. i guess i thought a buddy board was something else. i’m gonna give that a try.
