What is the Best Blade/Fence Alignment Gauge?
Forum topic by DavidNJ posted 12-20-2012 07:43 AM 3088 views 0 times favorited 3 replies Add to Favorites Watch
View DavidNJ's profile
DavidNJ
389 posts in 1989 days
12-20-2012 07:43 AM
So far, I’ve seen at least 4 tools sold for this purpose: A-Line-It form In-Line, Woodpecker Saw Gauge, and TS-Aligner Jr. All feature some bracket that fits in a miter slot and an inexpensive 1” dial indicator:
Most are in the $60-80 range.
As pointed out but a poster in earlier thread on this topic, these aren’t even the right time of dial indicators to use for this application. That would be a dial test indicator that moves back and forth of a range (typically under 30/1000ths) with higher accuracy.
Both gauges with a magnetic mount and different tips are available for very modest costs: http://littlemachineshop.com/products/product_view.php?ProductID=2925&category=1962771978
That leads to the problem of how to align with the miter slot. The fits include a bar for this; the Woodpecker gauge is clever with a roller resting on two smaller rollers. Others have built wood bases, similar to the slides on a crosscut sled.
However, can’t you just lead the edge of the V bottom of a standard magnetic mount in the miter slot?
What solution is best for aligning the blade and fence?
Thanks,
David
3 replies so far
View knotscott's profile
knotscott
8008 posts in 3371 days
#1 posted 12-20-2012 11:00 AM
I own one these….
...but only used it to verify that this works really well.
knotscott
#2 posted 12-20-2012 11:03 AM
I own one these….
...I used it to verify that these devices like these work really well.
or
View NiteWalker's profile
NiteWalker
2737 posts in 2572 days
#3 posted 12-20-2012 11:19 AM
My setup gauge is a $10 harbor freight dial indicator screwed to a block of wood with a runner for the miter slot (much like the last pic you posted David).
It works fine for me. Those pretty aluminum gauges are a waste of $$ IMHO, when the low tech approach works fine.
There’s another method using the miter gauge and a piece of wood with a brass screw in it.
One more thing, there’s no need to chase a million zeroes here; .003 or better is fine for blade to miter slot, blade to fence varies. I like to keep mine about .001-.003” out so the rear of the workpiece doesn’t touch the blade.
