menards oak
Forum topic by rf58 posted 12-20-2012 05:16 AM 1558 views 0 times favorited 6 replies Add to Favorites Watch
View rf58's profile
rf58
78 posts in 3084 days
12-20-2012 05:16 AM
what do they do to the laminated oad boards
it seems like it is compressed don’t take a stain very well
does anyone know what they do to that wood. the glue up is great and grain match is ok.but there is something about it ,
-- rf58, Illinois
View Ted's profile
Ted
2838 posts in 2085 days
#1 posted 12-20-2012 05:43 AM
Did you sand it first? Sometimes a very thin invisible layer of sap will harden, like varnish, slightly sealing the grain. It’s not just Menard’s oak, but all woods do this to an extent. That’s why surfaces that have been exposed for any period of time should be sanded before staining. Any pre-surfaced lumber you buy should be sanded for this reason, and also to get rid of the chatter marks, which you might not see until you apply a finish. I usually go over everything with 150 grit. This also applies to any wood you’ve had sitting around for a while.
-- You can collect dust or you can make dust. I choose to make it.
View rf58's profile
rf58
#2 posted 12-20-2012 04:08 PM
i have a piece left i will sand it deeper but i did roundover the edge and didn’t notice any difference
will try it.
-- rf58, Illinois
View REO's profile
REO
927 posts in 1948 days
#3 posted 12-20-2012 08:40 PM
teds got a good point. if they finished with a sander it most likely burnished the dust into the pores with the heat. if it is a planed board the same thing can happen. the edge has worn to the point that the edge burnishes the material behind the cutting edge.
be sure to sand with the grain prior to finishing.
View Ted's profile
Ted
#4 posted 12-20-2012 09:00 PM
The roundover edge would have shown a difference if the issue was limited to the surface, so apparently it’s not just the surface but the wood itself. Maybe they are foresting genetically modified oak, made to grow faster? Just a wild guess. Or maybe it’s a particular species of oak.
by the way, are you sure it’s red oak and not white oak? White oak is less porous and will stain differently from red oak. Just a thought.
View rf58's profile
rf58
#5 posted 12-21-2012 01:43 AM
IM GOING T RIP A PICE 1’’ WIDE AND SEE HOW IT FINISHES.
IM POSITIVE IT IS WHITE OAK YOU KNOW HOW YOU CAN TELL WHITE OAK FRMO RED OAK?**
-- rf58, Illinois
View rf58's profile
rf58
#6 posted 12-21-2012 02:07 AM
I JUST TOOK IT FOR GATIT IT WAS WHITE OAK BUT IT IS RED OAK
YOU CAN BLOW BUBBLES IN A GLASS OF WATER WITH A 3/4 X3/4 STICK OF RED OAK NOT WHITE OAK.
IT SAYS MAIDE IN AMERRICA I JUST COATED A RAW CUT AND A FACTORY FINISHED PIECE WITH SHELLAC
-- rf58, Illinois
