Splinters
Forum topic by George_SA posted 12-19-2012 08:23 PM 1278 views 0 times favorited 22 replies Add to Favorites Watch
View George_SA's profile
George_SA
370 posts in 2333 days
12-19-2012 08:23 PM
Topic tags/keywords: splinters slivers
Is it a problem for the rest of the LJ’s? I got one again tonight and it is always difficult to remove.
-- Sometimes life gets in the way of one's woodworking :)
22 replies so far
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2490 days
#1 posted 12-19-2012 08:39 PM
Maybe it was Woodsmith shop, or a magazine, or here, I don’t know, but it said to put a dab of wood glue over the splinter, and when it dries and you pull it off, the splinter will come out. I always just use the tweezers, and if that doesn’t work, utility knife.
View Kreegan's profile
Kreegan
1452 posts in 2267 days
#2 posted 12-19-2012 08:42 PM
These are very useful.
http://www.toolsforworkingwood.com/store/dept/TI/item/MS-SPLINT.XX/Professional_Splinter_Removal_Kit
I also use a very small needle stuck in an old wine cork.
117203 posts in 3697 days
#3 posted 12-19-2012 09:10 PM
I’ve never had much luck with the glue trick ,maybe it has to do with the size of the splinter.
View Richard's profile
Richard
400 posts in 2811 days
#4 posted 12-19-2012 09:22 PM
I think splinters are just a hazard of woodworking. A good pair of tweezers helps. I also use an inexpensive jewelers loop to get a good closeup view, which makes removal a lot easier for those little b@st@rds that you can barely see, but hurt like the dickens when you hit them just right.
-- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain
404 - Not Found
2544 posts in 3089 days
#5 posted 12-19-2012 09:39 PM
They can be nasty alright, read about Craftsmanonthelake’s adventure with splinters to see how bad they can get.
It’s the little ones you don’t notice for a day or two that are the worse.
View Nicky's profile
Nicky
695 posts in 4212 days
#6 posted 12-19-2012 10:47 PM
Have had my share. Tweezers usually work but sometimes I need to get my honey to dig.
Get these mostly when handling plywood. I’ve been using gloves when working with rough lumber, I should use when I’m doing any machining.
-- Nicky
View paratrooper34's profile
paratrooper34
915 posts in 3072 days
#7 posted 12-19-2012 11:07 PM
Nicky, gloves and machinery are a very bad mix. A bare hand will get cut for sure when exposed to machinery with some type of blade. A glove will get sucked into the works and make what could amount to a minor injury and turn it into a catastrophic, debilitating injury. Although I don’t use a lot of machinery, I will never use gloves with them. I am sure you will find this the general consensus around here.
-- Mike
Nicky
#8 posted 12-20-2012 01:21 AM
Paratrooper, I get the LJs sentiment about gloves. I use tight fitting gloves, so no loose ends to get caught. I have a healthy respect for my tools and myself. I’m of the opinion that gloves provide a level of protection, for me.
-- Nicky
paratrooper34
#9 posted 12-20-2012 01:37 AM
You do what you gotta do. Big boy rules and all that.
-- Mike
View BentheViking's profile
BentheViking
1782 posts in 2684 days
#10 posted 12-20-2012 02:02 AM
i feel like your not a real woodworker if splinters are not a part of your life
-- It's made of wood. Real sturdy.--Chubbs Peterson
View NiteWalker's profile
NiteWalker
2737 posts in 2697 days
#11 posted 12-20-2012 02:14 AM
I don’t get many splinters, but I learned a long time ago, the hard way, to try to slide my hands across wood as little as possible.
View Tyler's profile
Tyler
52 posts in 2132 days
#12 posted 12-20-2012 02:23 AM
not to whiip out my mancard but my hands are like leather/sand paper… my wife hates them
-- You can get alot further with a kind word and a hand gun, than just a kind word alone
View gfadvm's profile
gfadvm
14940 posts in 2810 days
#13 posted 12-20-2012 02:40 AM
I use a 21 guage hypodermic needle to remove splinters almost daily. I have to use a magnifier lens to see but these needles work like a micro scalpel.
View Monte Pittman's profile
Monte Pittman
29797 posts in 2458 days
#14 posted 12-20-2012 02:58 AM
It’s only a problem like daily some woods worse than others. WRESTLING SLABS IS EVEN WORSE.
View stan3443's profile
stan3443
301 posts in 2395 days
#15 posted 12-20-2012 04:09 AM
Tyler my wife agrea’s with yours
-- If your not supposed to have hair on your face......why does it grow their
