Safe stopped grooves - how?
Forum topic by opalko posted 12-19-2012 07:55 PM 1130 views 0 times favorited 9 replies Add to Favorites Watch
View opalko's profile
opalko
148 posts in 3277 days
12-19-2012 07:55 PM
Currently working on a project that involves a frame that holds a panel. The stiles of the frame actually extend up beyond the panel to another section that holds a mirror, which fits in a rabbet and not a slot. The lower panel goes into a 3/8” slot on all 4 sides. I’d love to cut this with a slot cutter but am in a bit of a time crunch to finish this and doubt I can get a bit here on time (I have one ordered btw, but it’s on backorder :( ).
In any case it looks like I have to do stopped grooves on the router table, which I dread. I’ve done them plenty of times before but they make me nervous as heck and invariably I end up ruining a piece when I go to lift the workpiece off of the bit.
What I usually do is mark the stops on the piece and the router table with penciled lines. When the lines line up, stop! I usually lower the piece onto the bit just inside the start mark at exactly the width of the bit (which is marked on the piece as well). Usually I don’t get it exactly right, have to go back and cut a little more and that is when the splinters fly!
Can someone share their technique that is safe and reliable?
Cheers
9 replies so far
View NiteWalker's profile
NiteWalker
2738 posts in 2819 days
#1 posted 12-19-2012 08:15 PM
A plunge router and guide will work.
View rum's profile
rum
148 posts in 2828 days
#2 posted 12-20-2012 12:13 AM
router to shy of the line and then finish with a small hand chisel.
View jumbojack's profile
jumbojack
1685 posts in 2866 days
#3 posted 12-20-2012 12:19 AM
Pre drill your stop. You will hear and feel the hole. Stop. Sometimes you may need to dress the stop with a chisel.
13641 posts in 3583 days
#4 posted 12-20-2012 12:31 AM
i put a longer board on the router table fence sometimes
and have stops on it for multiple pieces
then turn the router off and lift off the board
these other ways sound good too
depending on how many you need to make
View Dan Krager's profile
Dan Krager
4235 posts in 2476 days
#5 posted 12-20-2012 01:22 AM
+1 jumbojock.
It is also a good idea to secure the piece to be cut between the regular fence and a low fence, like a board laid flat and snugged up to the workpiece and clamped securely. Work your way into the depth of cut with multiple passes, taking maybe 1/8” per pass. You will find this safe, secure and predictable (with the holes at both ends, start and stop) and if you ruin a piece it will be because you fumbled it on the floor!
Best wishes.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Now there's a face that would stop a clock! And seriously mess with small watches.
View Lifesaver2000's profile
Lifesaver2000
556 posts in 3354 days
#6 posted 12-20-2012 01:59 AM
I kind of do all of what jumbojock, Dan and patron describe. Predrill the ends on the drill press, then use these holes as an accurate way to set stop blocks on a long fence for both the start and stop points. I also use a clamped board to hold the work piece tight against the fence, and take shallow passes.
When I type it out like that is kind of sounds like overkill, but it is accurate and has never felt unsafe.
View John Ormsby's profile
John Ormsby
1288 posts in 3979 days
#7 posted 12-20-2012 02:47 AM
You can send that old Ford tractor my way if you don’t need it.
Very cool. I learned to drive on one.
-- Oldworld, Fair Oaks, Ca
View Smitty_Cabinetshop's profile (online now)
Smitty_Cabinetshop
15832 posts in 2860 days
#8 posted 12-20-2012 02:51 AM
+2 for Jumbojock
View bandit571's profile
bandit571
22035 posts in 2925 days
#9 posted 12-20-2012 02:58 AM
Along with the pre-dill of a stop hole, BEFORE you lift the piece, shut the router off. A stopped bit can’t ruin much of anything.
