Epoxy for cutting board feet?
Forum topic by BinghamtonEd posted 12-19-2012 07:39 PM 1140 views 0 times favorited 6 replies Add to Favorites Watch
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2455 days
12-19-2012 07:39 PM
I’m wrapping up my edge grain cutting boards for Christmas presents. I plan on attaching 4 small feet to each board to keep it from slipping. I’ve got these ready to go.
It looks like you can just drill a hole and shove these in and they fit pretty tight, however I was thinking that if one came out, I didn’t want it to go down the drain and be lost forever. I bought some 5-minute epoxy and plan on putting a dab of that in each hole before putting the foot in, then once they’re all in, proceed with oiling the boards. Any reason not to epoxy the feet in?
View lew's profile
lew
12213 posts in 3841 days
#1 posted 12-19-2012 11:28 PM
I think that would work, OK.
I bought some larger ones that are “sticky” but didn’t trust that to hold very long. Used some short #6 screws and washers to hold the feet in place.
View jat's profile
jat
75 posts in 2857 days
#2 posted 12-20-2012 12:01 AM
I never put on feet. I have found that most people want to be able to use both sides or use one side and turn the clean side up for show.
View Biff's profile
Biff
126 posts in 2099 days
#3 posted 12-20-2012 12:37 AM
Yeah, well some of us have to put feet on the cutting board so they don’t wobble. Gotta get a drum sander!
-- Interested in Oregon property? Visit me at http://www.willamettepropertiesgroup.com
View DrDirt's profile
DrDirt
4426 posts in 3828 days
#4 posted 12-20-2012 12:42 AM
I would not use epoxy I would put a little blob of silicone, as it can be cut out later if you need a new rubber foot.
Epoxy will be a solid crust that you are ” stuck with” later in the boards life.
runswithscissors
2804 posts in 2110 days
#5 posted 12-20-2012 01:51 AM
I’m also dubious about epoxy sticking securely to polyvinyl. DrDirt probably has it right.
View AandCstyle's profile
AandCstyle
3136 posts in 2342 days
#6 posted 12-20-2012 01:59 AM
To keep them from slipping, just put a hand towel under them during use.
-- Art
