turning curly maple
« back to Woodturning forum
Forum topic by jerryo posted 12-19-2012 05:50 PM 2312 views 0 times favorited 8 replies Add to Favorites Watch
View jerryo's profile
jerryo
135 posts in 2834 days
12-19-2012 05:50 PM
Topic tags/keywords: question maple turning
Hi fellow lumber jocks. I recently bought some 8/4 curly maple for table legs for some tables and night stands I am going to make. I was wondering if anyone has turned curly maple and if there was lots of tear out? Any info would be much appreciated. Thanks, Jerry O
8 replies so far
View Gshepherd's profile
Gshepherd
1727 posts in 2072 days
#1 posted 12-19-2012 05:53 PM
Sharp Tools Jerryo, very sharp tools…... Other than that I have not had any problems….. Remember no pics it did not happen…...
-- What we do in life will Echo through Eternity........
jerryo
#2 posted 12-19-2012 06:03 PM
Thanks Gshepherd, Promise to take some pics, how high a grit do you go with the slip stones? Jerry
View tyskkvinna's profile
tyskkvinna
1310 posts in 2857 days
#3 posted 12-19-2012 06:11 PM
Sharp sharp sharp! That’s about it. I turn curly maple nearly every day. It sure does give pretty results.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View McLeanVA's profile
McLeanVA
488 posts in 3305 days
#4 posted 12-19-2012 08:18 PM
I have also turned curly maple. I haven’t encountered any worse tear out than normal maple.
-- Measure, cut, curse, repeat.
Gshepherd
#5 posted 12-19-2012 09:34 PM
Jerryo, I do not use any slip stones, I grind on a slow speed grinder (One-way jig) and deburr with 220 on a dowel or on a flat surface. Hope this helps….
View RogerM's profile
RogerM
786 posts in 2270 days
#6 posted 12-20-2012 12:49 AM
I think the entries pretty well cover it. Sharp tools are really the key to turning or working with curly maple.
-- Roger M, Aiken, SC
View franco88's profile
franco88
11 posts in 3584 days
#7 posted 12-20-2012 03:42 PM
One can only repeat the necessity of a sharp tool and an admonition to start slowly and feel your way into the heart of the task.
-- frank
View tamboti's profile
tamboti
207 posts in 3012 days
#8 posted 12-20-2012 06:09 PM
Hi Yes sharp tools wont help if you don”t have a plan of what the legs should look like. try drawing a rough full scale plan.Very important is the pommel this is the transition of the square section to round this should be no to subtle and not much but a slight curve from corner to corner of the sq section when you look at it side on.Regards Tamboti
-- Africa is not for sissies
