12" blade 5/8 arbor
Forum topic by CaptCoan posted 12-19-2012 03:25 PM 7490 views 0 times favorited 8 replies Add to Favorites Watch
View CaptCoan's profile
CaptCoan
39 posts in 2155 days
12-19-2012 03:25 PM
I have 2 12” radial arm saws that have 5/8 arbors ( Dewalt and Rockwell ) both of wich are 30 plus yrs old that currently have 10” blades on them, in my supply catalogs all the 12” blades have 1” arbors can anyone recommend a supplier that sells 12” blades with a 5/8 arbor. Thanks
-- EVERY MAN MAKES HIS OWN WORLD/ THE WORLD IS A BEAUTIFUL PLACE
8 replies so far
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3308 days
#1 posted 12-19-2012 03:35 PM
I believe the arbor on a 12” compound miter saw is 5/8”...you can get blades for those at big box stores.
-- jay, www.allaboutastro.com
View woody57's profile
woody57
650 posts in 3577 days
#2 posted 12-19-2012 04:09 PM
I have a 12” dewalt compound miter saw. It came with an insert that reduces the 1” hole to 5/8”.
You need to locate one of these inserts. I think any saw blade company would have them. In my area I would go to Butler Saw company in Lawrenceville GA.
-- Emmett, from Georgia
View Loren's profile
10477 posts in 3797 days
#3 posted 12-19-2012 04:22 PM
I am sure there are blades available with 5/8” arbors, but a bushing
works well too.
http://www.ebay.com/itm/BUSHING-REDUCER-ARBOR-FOR-SAW-BLADE-/200387392257?pt=LH_DefaultDomain_0&hash=item2ea804f301
View FirehouseWoodworking's profile
718 posts in 3423 days
#4 posted 12-19-2012 05:44 PM
I believe the ShopSmith tool (lathe/saw/everything) uses a 5/8” arbor, though I believe you may have to settle for only 10” blades. But they are quality blades! You should be able to get blades from them.
Try www.shopsmith.com
Cheers!
-- Dave; Lansing, Kansas
Cosmicsniper
#5 posted 12-19-2012 05:50 PM
Actually, I was mistake on that. My 12” blades are made for 1” arbors, my CMS having the capability to use either 1” or 5/8” blades because its dual arbored.
However, people can use 12” blades on a 5/8” arbor if they get a blade adapter like this…
http://www.amazon.com/Freud-BL71MCE9-1-Inch-8-Inch-Bushing/dp/B00004RK8A
Loren posted one as well.
View JoeinGa's profile
JoeinGa
7739 posts in 2156 days
#6 posted 12-20-2012 12:28 AM
Send me a message with your address, I’ll mail you a couple of the adapter washers.
CaptCoan
#7 posted 12-21-2012 07:49 PM
Thanks for the input everone, after reading the responce about the bushing I looked on the wall and tere they were covered in dust and shavings 2 bushings ( duuhhh). Thanks anyway joein10asee
HillbillyShooter
5811 posts in 2442 days
#8 posted 12-22-2012 12:26 AM
http://www.forrestsawbladesonline.com/product_618_NEW_12_CHOPMASTER_5_8_Bore__FREE_SHIPPING.html
http://www.forrestsawbladesonline.com/product_43_WOODWORKER_I_Saw_Blade_with_5_8_Hole.html
Both of the above work well on my 12” Delta RAS.
