« back to Woodcarving forum
Forum topic by Monte Pittman posted 12-18-2012 07:44 PM 1494 views 1 time favorited 8 replies Add to Favorites Watch
View Monte Pittman's profile
Monte Pittman
28594 posts in 2271 days
12-18-2012 07:44 PM
Topic tags/keywords: question
Just bought the long neck angle grinder from Proxxon. I have a few of the Sabuur Tooth carving wheels. I have a couple of the King Authur chainsaw wheels, but because of previous injuries, I probably won’t try them again. Any other do’s and don’t on this?
-- Mother Nature created it, I just assemble it.
8 replies so far
View SteviePete's profile
226 posts in 3236 days
#1 posted 12-18-2012 07:52 PM
I had some close calls with this whole family of tools. I changed direction and got the Stihl chainsaw dime and quarter bars and chains and got some directions on carving. Same worries just 8lbs heavier. I have gone the more protection route. Got leather palmed nomex/stainless cloth gloves. Added gauntlets made from old kevlar body armor. Getting good at toadstools ?? Look forward to carving information as folks get familiar with this forum. Thanks to all. steve
-- Steve, 'Sconie Great White North
View grizzman's profile
7836 posts in 3237 days
#2 posted 12-18-2012 09:26 PM
well with any of these hand held tools, make sure you have a good grip with both hands, its tempting to use one hand sometimes, but those things can jump, as your probably well aware of…i know the cutting wheels that are a finer grit are easier to handle and control..the coarse ones are a real handful…be careful monte…but enjoy your new tool..
-- GRIZZMAN ...[''''']
View bowtie's profile
990 posts in 2279 days
#3 posted 12-19-2012 12:41 AM
like griz said “use both hands” i like mine, easier to handle than a right angle grinder. watch the shaft lock i accidently hit mine at times.
-- bowtie,.....jus passin thru....
View Roger's profile
20916 posts in 2737 days
#4 posted 12-19-2012 12:59 AM
Do use it safely. Don’t cut any o yer digits off. :)
-- Roger from KY. Work/Play/Travel Safe. Keep your dust collector fed.
View Granddaddy1's profile
182 posts in 2135 days
#5 posted 12-19-2012 02:39 AM
I tried the Lancelot wheels and they scared me to death. I returned them the next day. I’d like to try the Gallahad wheels, but haven’t picked one up yet. Most of my stuff is done with flap sander wheels.
Be very careful!
-- Ron Wilson - maker of fine firewood!
View holzmichel's profile
23 posts in 2995 days
#6 posted 12-19-2012 11:43 AM
Carve carefully using both hands. Be careful not to overheat the engine.
Didn’t have problems with the sawburr, chainsaw or arbortech discs up to now, no matter what size.
View LittlePaw's profile
1571 posts in 3012 days
#7 posted 12-19-2012 04:09 PM
All comments above are excellent. I use mine quite a lot as it removes waste rapidly. But because it does remove wood very fast, I learned the best amount of pressure to apply on the wood by using it. I’d like to add a couple of suggestions. Wearing protective gloves could be a bad thing IF you allow your gloved digits to get too close to the running burr. I the saburr catches the glove, the result could be very bad. Secondly, be sure to hold it firmly with BOTH hands and move it always from left to right and not back and forth. Do not move it from right to left as it could run away or jump which could damage your work piece. I enjoy and use mine a lot when I need to remove wood quickly and accurately. It is easy to control especially with its adjustable speed. But as in all power tool, using it safely requires full attention/concentration when you have it running. Stop the unit and let it cool when it starts to get hot. If you are right handed, hold the long neck with your left hand as if you are holding a tennis racket and with the right hand around the body where the two pads are. I apply a firm grip with both hands and have had no problem controlling it. I prefer it over the Dremel – stalls and get too hot easily and waaay too loud!
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
View MichaelA's profile
778 posts in 2822 days
#8 posted 12-26-2012 10:26 PM
Monte try and think of these wheel tools as no different than a angle grinder or chainsaw. If you set the cutting edge into your work similar to driving a tip of a chainsaw into a tree. It will jump back at you. The same way a chisel will. That you sharpen on your grinder (wheel) if you pass the center of the rotation. Try some less aggressive wheels and if the proxxon is variable speed slow it down and practice on a 2×6 clamped down. If the proxxon has a handle use it. If it doesn’t keep both hands on the grinder don’t use any wheel or burr that is aggressive. Take a look at the arboretech guard that comes on the 2” grinder. They have placed it so the owners don’t use the part of the cutting wheel that can easily hurt the operator. I know any tool can bring hrs. of enjoyment. Also wear protective clothing and safety glasses as these wheels can and will send wood chips flying.Well Monte be safe and enjoy your new tool.Keep on being creative and I look forward to seeing your next project!!!!!!!!!!!!
-- The best and most beautiful things in the world cannot be seen or even touched. They must be felt with the heart. "Helen Keller"
