Help with a precise cut
Forum topic by JNP posted 12-18-2012 06:10 PM 1461 views 0 times favorited 25 replies Add to Favorites Watch
View JNP's profile
JNP
113 posts in 2576 days
12-18-2012 06:10 PM
Hello All.
Looking for some help from the many experts on this board. My nephew and I are making a folding hunting knife as a gift for his dad. We need to fashion some handles to attach to the liners and bolsters and the match has to be a very precise fit.
I am trying to duplicate a curve that will align the handles (scales) with the bolster. I have cut it out on the band saw and tried to use files and rasps but I’m not getting the results I’m looking for
Are there any ideas on how to mate the handles to these curves?
-- Jeff
25 replies so far
10395 posts in 3646 days
#1 posted 12-18-2012 06:15 PM
Router template. Make a template (and a jig to
clamp the template to the work and support the
router… or do it on the router table).
The template should fit the metal part as close
as you can manage.
You may be able to use a bearing-guided 1/2” diameter
dado clean-out or trimmer bit with a 1/4” shank. If the
1/2” bearing will follow the inside curve it will work.
View RRBOU's profile
RRBOU
176 posts in 2291 days
#2 posted 12-18-2012 06:16 PM
I would try a small pattern bit in a trim router.
-- If guns cause crime all of mine are defective Randy
View pintodeluxe's profile
pintodeluxe
5659 posts in 2812 days
#3 posted 12-18-2012 06:20 PM
Make sure to use a jig to keep your hands clear of the bit.
View Bill White's profile
Bill White
4930 posts in 3959 days
#4 posted 12-18-2012 06:29 PM
EXPERT????
An expert is a guy with a briefcase, and is more than 6 miles from home. :))))
Yep! Router!
Bill
-- bill@magraphics.us
View Scott's profile
Scott
121 posts in 2223 days
#5 posted 12-18-2012 07:18 PM
I might be going against the grain on this, but I’d trace that profile onto your stock and cut it really carefully on the band saw. Maybe leave a hair extra and sand to the final match.
View JNP's profile
JNP
#6 posted 12-18-2012 07:42 PM
I think I’ll try the pattern bit. I used a flush trim which clearly didn’t work as the curve diameters are enlarged by the size of the bit.
I also saw this jig that JL7 made and I think it might do the job.
-- Jeff
117091 posts in 3576 days
#7 posted 12-18-2012 07:58 PM
I Agree a pattern might be the way to go but I would be very careful trying to route a small piece.You might think about keeping it long and cutting it of after you have routered the shape you want. I would also think about just cutting this out on a band saw and sanding the top contour.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3584 days
#8 posted 12-18-2012 08:01 PM
I’m with Scott it can’t be that hard to do if YOU take your time and re-check every few seconds during the trimming sanding. Alistair
#9 posted 12-18-2012 08:05 PM
If I just wanted to do a few scales I would scribe the parts
using the metal part as a pattern… then there’s an incised
line to work to. Cut close to the line and then carve and
sand to the line.
If you have a disc sander, a curve can be shaped on the
edge of the disc if the paper isn’t too worn. Same thing
with a narrow belt sander.
View PurpLev's profile
PurpLev
8535 posts in 3647 days
#10 posted 12-18-2012 08:13 PM
generally speaking – a router with a bearing straight cutter (template cutter), but since this is a rather smallish part, I’d cut it as close as I can, and shape it by hand + sanding to final shape. small cuts, sand slowly and you should get there eventually.
View JNP's profile
JNP
#11 posted 12-18-2012 08:29 PM
I’m rethinking this and may be missing something…I don’t want an exact copy of the bolster, I want an exact mate.
If I rout around the bolster w/a 1/4” template bit the resulting mating piece curves will be 1/4” larger no?
-- Jeff
#12 posted 12-18-2012 08:37 PM
You need a flush cut bit.
View Surfside's profile
Surfside
3389 posts in 2172 days
#13 posted 12-18-2012 08:54 PM
In that situation , you need to be a little more patient with band saw or let the router to the job. :)
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
SCOTSMAN
#14 posted 12-18-2012 08:56 PM
Like I said if you take your time and check very regularily then you should be spot on.This is not as difficult as it seems. Have fun though and keep relaxed. Alistair
View teejk's profile
teejk
1215 posts in 2683 days
#15 posted 12-18-2012 09:55 PM
I always wanted one of those spindle sanders…someday I’ll get one.
Your sides are going to be maybe 1/4” thick (if that) and I don’t know how a router will handle that. even a small drum sander on a drill press will work (slow speed and fine grit). I’d say rough it out on the bandsaw and then pretend you are a brain surgeon.
