Tweaking a Delta 32-100 plate joiner
Forum topic by KGRRSteve posted 12-18-2012 04:46 AM 10649 views 2 times favorited 4 replies Add to Favorites Watch
View KGRRSteve's profile
KGRRSteve
28 posts in 2189 days
12-18-2012 04:46 AM
Topic tags/keywords: 32-100 biscuit joiner
Bought a 32-100 plate joiner a few months back off from Craig’s List. Couldn’t pass up the deal.
Did some reading, and from what little information was out there it seemed like people liked the unit, but found the foot operated feed mechanism to be the weak point. So for fun, I disconnected the cable and foot pedal and built a simple lever arm to feed the cutter into the work piece.
I haven’t put it to the test yet and I don’t know if I really need this kind of unit (which seems geared more towards higher volume biscuit slot cutting than the Porter Cable hand unit I have been using).
Anybody have experience with, or thoughts about, this unit?
-- Life has no remote. Get up and change it yourself.
KGRRSteve
#1 posted 12-18-2012 06:37 PM
A couple of reference links:
http://www.woodweb.com/knowledgebase/StationaryBiscuit_Joiners.html
http://www.normstools.com/images/normstools/32-100.shtml
KGRRSteve
#2 posted 01-04-2013 10:05 PM
Nobody here has used one?
View AlaskaGuy's profile (online now)
AlaskaGuy
4764 posts in 2507 days
#3 posted 11-20-2013 06:08 PM
I know this is an old thread but I just found it.
I’ve had a Delta 32-100 for many years. I only use it for face frame stock but it really excels at that. I added an air cylinder because the original food feed didn’t work that well. The rest of the machine works great.
[IMG]http://i119.photobucket.com/albums/o159/rmccomas0043/BJLarge.jpg[/IMG]
KGRRSteve
#4 posted 11-21-2013 06:42 AM
I like that air cylinder mod. What kind of control valve is that? Can you control the cutter feed rate with it?
So far I’ve been really happy with the simple hand lever I’m using. I’ve only used it on 1/2 dozen projects (at most), but it does a nice job and it’s quick to locate and clamp stock and cut consistent slots.
