| Forum topic by duster | posted 157 days ago | 463 views | 0 times favorited | 5 replies | ![]() |
157 days ago |
While assembling a base cabinet, screwing a support to a hickory plywood side panel I stupidly inserted a screw a little to deep. It did not go thru but it did cause a bump in the hickory skin—- actually three bumps. Hopefully there are some woodworkers out there smarter than I that can help me out of this dilemma.I discovered the problem as I was setting the side panel to apply a finish, Help would be greatly appreciated. Duster |
5 replies so far
#1 posted 157 days ago |
remove the screw sand out the bump. Sadly if you dont sand the hole panel, you might see it when you stain it. you could take a damp rag, place a hot iron on the rag thats over the bump which will expand the fibres……let dry, sand the whole panel smooth -- "Good artists borrow, great artists steal”…..Picasso |
#2 posted 157 days ago |
read above, However if you want to flatten the panel first you can always put a block of wood on it, and strike it with a mallet, usually this will remove a bump, and the block will keep you from getting a dent! But if you get a dent, just get out a clothes iron, fill it with water, turn it as high as it will go and set it to steam, it’ll pull it right out. -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#3 posted 157 days ago |
Yeah I have bad luck sanding out the bumps, a few times I’ve sanded through the veneer and left a hole so I try flattening first. -- -- Rick M. |
#4 posted 157 days ago |
Ditto the block idea first….it usually works for me depending on how bad the bump is. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
#5 posted 157 days ago |
Thanks for the reply’s guys—guess I haven’t hit the bumps hard enough.Will give it another try. Thought Imight try a block and clamp—see if I can get a little more pressure without causing a dent. Let you all know if it works. Thanks again. |
| Forum | Topics |
Woodworking Skill Share
8797 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1536 |
3553 |
15803 |
Hand Tools
2038 |
Jigs & Fixtures
496 |
Wood & Lumber
2845 |
810 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6163 |
