High build, photo safe, water based clear coat?
Forum topic by bh442 posted 12-18-2012 02:56 AM 3075 views 0 times favorited 7 replies Add to Favorites Watch
View bh442's profile
bh442
21 posts in 2131 days
12-18-2012 02:56 AM
Hey guys, I’ve tried looking around a bit, but with no luck.
Right now I’m spraying (hvlp) a water based, gloss, polycrylic (Minwax) over pictures which were printed on photo paper off a inkjet printer.
What I’d like is get a good, high build, to help give the affect of ceramic tiles (instead of paper on wood) but after 6 coats, the polycrylic is still just too thin.
I’d like to stay water-based for the purpose of simple cleanup. If I have to switch to oil, so be it, but water would make me happy.
Any advice from the pros?
*That white, streak / blotch on the project is just the effects on the printed photo, not from the clear coat.
-- Bill - Wattsburg, PA.
7 replies so far
117063 posts in 3542 days
#1 posted 12-18-2012 03:31 AM
Looks super.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2496 days
#2 posted 12-18-2012 08:05 AM
Target Coatings’ EM7000HBL, maybe… water-based, clear, designed for a high build
-- Mark Kornell, Kornell Wood Design
View skipj's profile
skipj
97 posts in 2238 days
#3 posted 12-18-2012 02:45 PM
I use target coatings EM6000 production lacque and get a pretty good build. I would give target tech. support a call and ask jeff if it will work,he is very much in the know. You can get free shipping and up to 30%
off with this Dec. promo code DCX12
View tyskkvinna's profile
tyskkvinna
1310 posts in 2951 days
#4 posted 12-18-2012 02:48 PM
What about bar top? It would have the depth of ceramic tile.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
bh442
#5 posted 12-18-2012 04:00 PM
Thanks for the Target Coatings reference. For some reason I believe I had looked through their products at one time, yet must have missed the high build coating.
I ordered the em7000.
I’m assuming you guys are spraying it on… what size nozzle are you using with your gun?
@tyskkvinna
Thanks for mentioning bar top. That type of finish was actually what crossed my mind first. After reading up on applying it and watching a few videos, I was split on trying it or not. I knew it’d give the finish I was looking for, but it appeared to be a bit more work, and a mess to work with. That and I was also worried with it being self-leveling, if it’d fill in the “grout” lines. So I figured I’d keep it in consideration if I couldn’t find anything more easier and cleaner to work with.
View Clint Searl's profile
Clint Searl
1533 posts in 2326 days
#6 posted 12-18-2012 09:46 PM
Bona Mega floor finish.
tyskkvinna
#7 posted 12-19-2012 01:24 AM
It does self level and would fill in “grout lines” if you poured it all in one go… I use it all the time and it is not much work, though it does take a little knack to get it exactly the way you want it, since it can be pretty darn thin or I sometimes use it cast up to 3” thick.
