Question from newbie
Forum topic by fatty posted 12-17-2012 10:12 PM 998 views 0 times favorited 10 replies Add to Favorites Watch
View fatty's profile
fatty
9 posts in 2032 days
12-17-2012 10:12 PM
Has anyone ever used Red Elm for outdoor furniture projects? I’m going to try my hand at some Adirondack chairs and I’m just not a big fan of cedar.
10 replies so far
View Dan Krager's profile
Dan Krager
4032 posts in 2257 days
#1 posted 12-17-2012 11:40 PM
I wouldn’t waste my time on red (or any) elm. Almost anything would be better. If you don’t like any of the cedars, any of which is one of the best choices, go with mahogany, teak, or yellow pine. Composites are also a possibility.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com One should always prefer the probable impossible to the improbable possible.
View Don W's profile
Don W
18754 posts in 2590 days
#2 posted 12-17-2012 11:43 PM
How about white oak? I’ve use elm (made my bench from it) but wouldn’t choose it for outdoor furniture.
Rick Dennington
5908 posts in 3217 days
#3 posted 12-17-2012 11:59 PM
Elm…not good for outdoor stuff….I’d ” El Paso ” on it…..find something else…...
View eaglewrangler's profile
eaglewrangler
64 posts in 2560 days
#4 posted 12-18-2012 12:34 AM
there are a number of naturally rot resistant woods, the tropicals like purple heart IPE and others, but they are harder to work and I burned some IPE in a plug cutter and it was worse than pepper spray. But there are a number of native woods that are rot resistant as well. Locust, while not native, is plentiful here and I use it in outside stick style and for bench legs. plum is very resistant, and less so cherry. I like the white oaks, especially chestnut oak (which tend to grow slower and tighter grained).
Even so I have used hickory and ash and other woods in outdoor benches from slab cuts. Understand that they have a limited use, around 10 years, which compared to the metal patio furniture my wife got, which is rusting after just a few years, seems like a decent time.
So your elm may rot in a decade, but keep them out of the dirt and they might outlast your car and refrigerator and washing machine.
Don W
#5 posted 12-18-2012 12:42 AM
I’m not sure I’d worry so much about the elm rotting away, a good finish will take care of that, elm is pretty unstable with moisture changes. Its ok for internal stuff. Outside…....not so much.
View Monte Pittman's profile
Monte Pittman
29383 posts in 2361 days
#6 posted 12-18-2012 03:25 AM
For outdoor furniture I don’t see it. I have quite a bit of elm and it takes patience to work with. Warps easy. BUT, it can be very beautiful if taken care of properly.
View WDHLT15's profile
WDHLT15
1747 posts in 2499 days
#7 posted 12-18-2012 03:36 AM
BTW, black locust, Robinia pseudoacacia is native and would be the second best choice for this use. Osage orange would be the best, but it is very hard to get.
White oak would be my choice. Elm has spiral grain and wants to twist and warp with moisture changes, and the moisture changes in outdoor furniture can be extreme.
Rick Dennington
#8 posted 12-18-2012 05:06 AM
Osage orange is what the Native Indians used to make their long bows with….not sure about the arrows…..
View moke's profile
moke
1179 posts in 2799 days
#9 posted 12-18-2012 04:30 PM
Elm always has made my shop seem bad…...
-- Mike
View SteviePete's profile
SteviePete
226 posts in 3326 days
#10 posted 12-18-2012 08:52 PM
I have both white and red elm. Old references says Red is better than White but both should be kept off the ground. Paint should take care of that. Same source says black walnut (heart only), American Hop Hornbeam and Black Locust. I’d be sure the RE was dry and flat. You will be disappointed if you expect to hold its form like Oak or Ash. I will try cypress next summer. Try the Red Elm —if it doesn’t work out you’ll have the most gorgeous firewood.
Red Elm has a distinctive odor when worked indoors—- think of Cub Scouts putting out the campfire. It was very difficult to dry—2 years in bole, two years in warm, dry garage. Ripped thin on bandsaw and just before the end of the cut WATER came out of the pores? I’ll wait a while longer. On Wisconsin, Steve
-- Steve, 'Sconie Great White North
