| Forum topic by tyskkvinna | posted 183 days ago | 631 views | 1 time favorited | 16 replies | ![]() |
183 days ago |
I have been asked to make some ornaments from logs – it will basically just a slice of log, with a hole for the ribbon (and some engraving but that’s not important to the question). The customer is very insistent that the pieces have the full bark around the edge… they will be able 2-3” dia. How do I keep the bark in-tact? I work with bark regularly but it is in smaller pieces. I’ve found that when it is a full ring, it tends to kind of dry against the wood and fall off. These are not Christmas ornaments, so I am not under a crazy time crunch. I am not 100% sure what kind of wood I will use but it is likely that I will use Maple. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
16 replies so far
#1 posted 183 days ago |
I wonder if you could soak it in CA glue to ensure adhesion? Kind of thinking out loud here, no real life experience in doing such as thing. -- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty |
#2 posted 183 days ago |
Type of wood makes a difference. Some types of wood simply don’t hold their bark well. As long as they aren’t going to be banged around a lot, I have had decent luck with my finishes holding it in place. Of I get a loose spot I glue it. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#3 posted 183 days ago |
if this is coming from an already dried log then the bark might want to come off when you cut it, what if you tightly wrap surran wrap around it and cut your slices, then you can see if you need to add some glue to hold it on or maybe it will stay on by itself, using hot glue might be a quick way to hold it on…well good luck…i hope it works. -- GRIZZMAN ...['''''] |
#4 posted 183 days ago |
Hi Lis. When a log dries, it shrinks and gets smaller than the bark and the bark falls off. I don’t know what the final product can look like, but it see that if you want to keep the bark on the log, you might need to put an adhesive between the bark and the log. maybe and epoxy soak might do it. I think maple bark will stay on better than oak or some other real thick bark trees. -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! |
#5 posted 183 days ago |
Would a film of polyurethane help in two ways—slow/inhibit moisture loss, and encapsulate the two unlike materials? LIke Chris, I’m thinking out loud. Or typing out loud. Something. For some reason I see shrub type material here: lilac for example. Kindly, Lee -- "...in his brain, which is as dry as the remainder biscuit after a voyage, he hath strange places cramm'd with observation, the which he vents in mangled forms." --Shakespeare, "As You Like It" |
#6 posted 183 days ago |
When turning natural edge bowls etc… it is a common practice to soak the bark with thin CA glue. I have used this method many times with great success. You do need to be careful during the turning process and ensure that you only cut from the bark toward the wood never outward toward the bark. I hope this helps…. Chris -- "Everything that is great and inspiring is created by the individual who labors in freedom" -- Albert Einstein |
#7 posted 183 days ago |
I’ve heard it has to do when the wood is harvested .The woods that hold there bark best are harvested in the winter. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#8 posted 183 days ago |
Hmmm – I was hoping to do it with some logs I already have (that are maple). I want the final product to have kind of a matte finish—wonder if I can do that with epoxy?! Worth trying! That would certainly keep the whole thing sturdy when it’s done. I really dislike CA glue and try to avoid it for anything other than glueing small pieces together … but I will give it a shot too. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
#9 posted 183 days ago |
Try soaking it in a wood conditioner for a couple days. I know Charles Neil’s blotch control will firm softer punkie wood if you soak it and let it dry out well . -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#10 posted 183 days ago |
use the epoxy pour on, you must encapsulate it , or the bark will come off, this will give you a high gloss finish, then sand it smooth and using a spray can of satin lacquer, that will give you the sheen I have done alot of these and this is the only way I have found to keep the bark on. thin the first coat of epoxy about 30% with acetone., brush it on , soaking the wood, it wont be pretty, then after this is dry (about 24 hours) sand and do a 2nd coat full strength . This may help http://intheworkshop.wordpress.com/2010/10/19/clario-slab-finishing-and-stuff/ |
#11 posted 183 days ago |
A small walnut tree holds bark well, but the bark isn’t very thick. If you find a branch that is straight and the right diameter, just cut it with a chainsaw and see if the bark holds tight. All of it will fall off eventually though. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#12 posted 182 days ago |
The only product I know that reliably keeps wood from shrinking is polyethylene glycol. It’s not pricy and can be reused and will handle very large chunks of logs (4 ft dia and up). Thin slices of small dia like you mentioned won’t take long, maybe a couple weeks soaking. The PEG works by capillary action replacing the moisture in the log with its own cells which are essentially plastic. Then when that process is complete (you can’t tell by looking, only experience-your own or someone else) you can dry the log slices and they will not shrink. The bark will tend to stay on if it was firmly attached at the start. You have essentially created a piece of plastic that looks like wood. You can machine it, finish it, and be confident that it won’t move unexpectedly. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
#13 posted 182 days ago |
AWESOME!!! Thank you! I will check that out. I am patient, don’t mind waiting while it soaks. -- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt |
#14 posted 181 days ago |
super glue should work -- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them. |
#15 posted 181 days ago |
The log slices HAVE to be stabilized for success. Some are naturally pretty stable, but none enough to keep the bark on when the slice splits. I’ve never seen glue keep a log slice from “pie cutting” splits, which tears the bark off because they don’t move at the same rate. Trees whose live edge will stay on a board indefinitely will shed their bark quickly from a log slice. Whole different action. I agree with TCC that glue can be successful in holding bark on a live edge of a board, but not on a log slice. -- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com |
| Forum | Topics |
Woodworking Skill Share
8845 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15977 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2775 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
