| Forum topic by LSGss | posted 154 days ago | 529 views | 0 times favorited | 6 replies | ![]() |
154 days ago |
Topic tags/keywords: question Hello all, I needed help with a design question. I am making a watch box out of african mahogany. My plan is for it to be two tiered with a bottom pull out drawer and a glass lid that opens up to the top drawer. The approximate dimensions are 12” H x 14” W x 10” deep. I plan to use 5/8 lumber for the box. The questions I have are: Please let me know if you have any advice. Thank you. |
#1 posted 154 days ago |
1) a 12×14 bottom is definitely too large not to worry about wood movement. If you have the capability, make your own mahogany plywood for the bottom – 3 to 5 layers. Might be easier to laminate mahogany veneer (shopmade or otherwise) onto plywood or MDF, both sides of course. Or use a frame and panel design, which might make the bottom thicker than desirable. 2) 1/8 is sufficient. 1/4 is thick, heavy and way overkill for the application. -- Mark Kornell, Kornell Wood Design |
#2 posted 154 days ago |
A drawing might help. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#3 posted 153 days ago |
LSGss, welcome to LJ’s by the way. I was just going thru the posts since last I’ve logged on and followed around an interesting link. The target of the link points to an article of an exceptional box maker who is also a member here. If you chase around the projects and blogs by him you will see some beautifully executed examples of artwork in both the literal interpretation and craftsmanship. |
#4 posted 153 days ago |
I always put glass in a rabbet and glue it in place with Lexcel caulk. It is a very clear ,rubbery, mineral spirit base caulk. Takes a few days to cure fully,but remains flexible. It will not release and pull out in a strip like silicone will. -- Fine Custom Woodwork since 1978 |
#5 posted 153 days ago |
I would go with veneered ply. If the bottom is to be captured completely. As stated above frame and panel construction with a solid mahogany bottom would work as well. Quarter inch ply, which is not really 1/4” and veneer on both sides fits perfectly in a 1/4” slot. -- Made in America, with American made tools....Shopsmith |
#6 posted 153 days ago |
Here are my drawings, I typed in the writing because I have bad handwriting. I apologies if I don’t know how to draw. If you see a question mark or a range of values that means I am still deciding or don’t know, feel free to comment. Thank you for everyone’s help. |
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1525 |
3543 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6151 |
