Round over edges or cut dadoes first on oak?
Forum topic by TopamaxSurvivor posted 155 days ago 462 views 0 times favorited 9 replies Add to Favorites Watch
TopamaxSurvivor
13192 posts in 1844 days
155 days ago
Topic tags/keywords: round over edges cut dadoes first oak
Since oak is a bit splintery, would you round over the edges of a board first or cut the dadoes, then round over?
9 replies so far
View Mip's profile
Mip
232 posts in 246 days
#1 posted 155 days ago
If you’re routing the end grain with the roundover, and the dadoes are with the grain, rout the roundover first. This way you won’t tear out the grain on every dado when you cut them. I made a card holder for my Dad with some fancy routed bead around the board, and I did it this way. Hope this makes sense.
View jim C's profile
jim C
1400 posts in 1266 days
#2 posted 155 days ago
I agree with Mip
-- Government does not solve problems; it subsidizes them.
87068 posts in 1745 days
#3 posted 155 days ago
Depends where the dado is Bob. If your concerned about tear out on the end-grain. rout the right hand first doing a climb cut(right to left ) just for a couple inches then go back and rout the rest the proper way left to right .
TopamaxSurvivor
#4 posted 155 days ago
Thanks guys, Guess I should have explained a bit more. There are dadoes 2 1/2” wide across grain on board 66” long. 2 of the dodos will be on the ends and one in the middle. I am mostly concerned about tear out / splintering on the sides when I do the dadoes, if I round over first; but then I’m just a wanna be WWer ;-))
Thanks for the reminder about climb cutting the end grain.
34369 posts in 2568 days
#5 posted 155 days ago
With a bearing bit you have to be careful that the bearing doesn’t fall into the dado slot because that will mess up the round over. With a fence it isn’t quite the same problem.
View renners's profile (online now)
renners
1889 posts in 1137 days
#6 posted 155 days ago
You could always clamp a spelch block on to avoid tearout at the ends.
-- Do or do not, there is no try
TopamaxSurvivor
#7 posted 155 days ago
I will be using a fence. Thanks for the pointer Karson. Never know when that learning curve mistake would show its ugly face to me ;-)
Good idea Jonathan, I’ll do that.
TopamaxSurvivor
#8 posted 155 days ago
Not sure what a spelch block is? Sort of like using a filler?
View bluekingfisher's profile
bluekingfisher
808 posts in 1147 days
#9 posted 154 days ago
Bob, I agree with with has been said before. in addition I would think about scoring the edge of the proposed dado cut to further reduce the likelihood of tearout.
Make sure too aned have a backer against the edge you will exit from, this again reduced the “blowout”.
Good luck, let us know how you get on.
David
-- No one plans to fail, they just, just fail to plan
