Jointer knife question...(Updated)
Forum topic by dakremer posted 12-16-2012 08:13 PM 1623 views 0 times favorited 33 replies Add to Favorites Watch
View dakremer's profile
dakremer
2683 posts in 3175 days
12-16-2012 08:13 PM
I just bought new knives for my jointer, and realized they are not a match to the old ones. The new knives are taller than the knives that come with it. My question is, how far can the knives stick out above the slot in the drum? I already have my old knives out – they are nicked up and need sharpened. I need to use my jointer today. Obvioiusly I can get the old knives sharpened (and thats what I’m going to do) – but can I use the new knives???
Thanks in advance
Here are some pics of one of the knives out….
There are springs on the bottom – I dont see a really great way of fine adjusting the knives. So whats the method for this? I did notice that the knives were not bottomed out to the bottom of the slot…are they not supposed to be??
-- Hey you dang woodchucks, quit chucking my wood!!!!
33 replies so far
View Dusty56's profile
Dusty56
11819 posts in 3772 days
#1 posted 12-16-2012 08:20 PM
If you install just one of the taller knives , then make sure it doesn’t hit anything when you set the tables to the correct height and turn the head slowly by hand.
That was a problem that I recently had with my replacement knives…....back to the supplier they went.
View Roger's profile
Roger
20931 posts in 2888 days
#2 posted 12-16-2012 08:36 PM
How much taller? an 1/8, 1/16, 1/32??? Maybe yours were that tall when the jointer was new…? If they are considerably taller, then, the return shouldn’t be a problem. I do feel your pain tho. Especially bein excited to get that beast runnin.
View Grandpa's profile
Grandpa
3260 posts in 2759 days
#3 posted 12-16-2012 08:45 PM
Install below the outfeed table. They shouldn’t flex that much. If you can get the table above them you should be okay.
dakremer
#4 posted 12-16-2012 08:45 PM
A lot taller. Like 1/4”
Grandpa
#5 posted 12-16-2012 08:47 PM
That much might have been ground off but I doubt it. How did you finally get the bolts out??
dakremer
#6 posted 12-16-2012 08:47 PM
It will stick above the slot in the drum by a little over 1-4”....
dakremer
#7 posted 12-16-2012 08:52 PM
I had to cut them. Heating them didn’t work because they were so rounded over I couldn’t get even a good wrench to not strip them….
Grandpa
#8 posted 12-16-2012 08:56 PM
Well do they fit below the table and not strike anything?? What is the decision here?
dakremer
#9 posted 12-16-2012 08:59 PM
I haven’t put them in yet. Will find out soon. Just was wonder if its dangerous to have the knife sticking out farther from the slot than normal
View teejk's profile
teejk
1215 posts in 2768 days
#10 posted 12-16-2012 09:24 PM
just an observation…most jointers allow for depth adjustment and unlike the portable planers, the knives can be sharpened. is it possible your old knives have been sharpened such that they are narrower?
you don’t mention the brand or model but I’m sure the specs for the machine are available.
dakremer
#11 posted 12-16-2012 09:29 PM
The brand is a Sunhill
View Jim Jakosh's profile
Jim Jakosh
20919 posts in 3189 days
#12 posted 12-16-2012 11:20 PM
I don’t know that there is a problem of them sticking out too far past the drum unless they hit something- like the edge of the tables in the process. It might be that the table cannot clear the cutter with wider knives. I guess the best thing to do it to install them and turn the drum by hand to see if there is interference anywhere.
Were these what was specified for that model jointer or are them some kind of universal set?
............Jim
dakremer
#13 posted 12-16-2012 11:27 PM
They are a universal set….
I’m trying to find the manual for my jointer now…
View MNgary's profile
MNgary
303 posts in 2501 days
#14 posted 12-16-2012 11:41 PM
Building on teejk’s entry, They may be taller, but whhen you lower the depth adjustments in the head it may be they won’t protrude that much more than the old ones.
-- I dream of a world where a duck can cross the road and no one asks why.
dakremer
#15 posted 12-16-2012 11:51 PM
I can’t find the manual online for it – does anyone know the bolt size for the knives in the drum
obviously the easy thing to do would be take an old bolt to the store with me…..however the shop is in one direction and the store is in the other….
Does anyone know the size???
showing 1 through 15 of 33 replies
