mortise jig
Forum topic by SqPeg posted 12-16-2012 07:11 PM 1283 views 0 times favorited 6 replies Add to Favorites Watch
View SqPeg's profile
SqPeg
15 posts in 1865 days
12-16-2012 07:11 PM
Topic tags/keywords: jig
I am making a large picture frame, 25×36x5” wide members and mitered corners. Does anyone have a jig that will hold the pieces so the mortises can be cut with a benchtop mortising machine?
View Loren's profile
9774 posts in 3523 days
#1 posted 12-16-2012 07:27 PM
Leave the mortised boards overlong and mortise them
as normal, then cut them off at the miter angles.
runswithscissors
2604 posts in 1900 days
#2 posted 12-17-2012 01:22 AM
Loren’s suggestion is good, but I think your mortiser may be able to cut those even with the miters already cut. Just be sure the molding is securely clamped. I assume you are planning on a spline tenon to go in the mortises?
SqPeg
#3 posted 12-17-2012 02:21 PM
yes it will be a blind spline 1/4×2”. The frame sides are 25” long so. I have to hold them at a 45 degree angle under the head of the mortiser so the bit will go in perpendicular to the face of the miter. Not sure how or if it can be done and still move the stock so that the bit will cut the entire lenght of the spline.
I get the feeling a bench mortiser is limited to doing only do miters in butt joined parts
View casual1carpenter's profile
casual1carpenter
354 posts in 2351 days
#4 posted 12-17-2012 04:04 PM
SqPeg, my take on the postings above, I think this shows it somewhat…...
Is this what you had in mind? Perhaps not, but it could be a solution.
View pintodeluxe's profile
pintodeluxe
5545 posts in 2688 days
#5 posted 12-17-2012 06:38 PM
I havn’t had to use any special jig for projects that size using my benchtop mortiser. If the workpiece is too wide to fit under the hold down, I install a riser block to raise the machine up enough to allow clearance.
Just curious, what problem would a jig solve for you?
SqPeg
#6 posted 12-18-2012 01:47 AM
I spent some time in the shop today and find that both suggestions will work. I have been over-thinking the situation. A jig is not necessary. In my case it is the old adage, ‘shoot the engineer and build the project’.
