| Forum topic by channeleaton | posted 185 days ago | 526 views | 0 times favorited | 8 replies | ![]() |
185 days ago |
Hello everyone! I’m gearing up to create my garage workshop and would like some input on my workbench(s). The plan I am looking at is this one from Fine Woodworking. I know many of you have seen it before. My question is, will this bench still be steady if I forego the front stretcher to accommodate a chair or rolling cabinets? |
8 replies so far
#1 posted 185 days ago |
Hi. Could you perhaps replace the stretcher with some stout diagonal braces, as long as possible while still leaving room for chair/cabinet? You’re going to want something there. Otherwise there isn’t much to keep the legs stable. Or, what about built in cabinets, leaving the stretcher, and maybe make the top overhang on one end for a stool? |
#2 posted 185 days ago |
It would rack and wobble pretty badly. I built that same plan for my first workbench. The stretchers are integral to the design. You’ll be tightening the bolts fairly regularly if you live somewhere the humidity varies a lot like I do. Rich;) -- Rich;) -"Dada make a big mess?" "Yes Dada made a big mess." |
#3 posted 185 days ago |
channeleaton, this bench is a very nice one. I built this very bench from the same source for my first and it served me well. I upgraded to an Ulmia but I still have that one in my shop. I think it would probably be a bad idea to remove that front stretcher if you plan on using tools that will wrack the bench (hand planes!). If you do not do work that will cause the bench to wrack, 45 degree braces would be a good substitute to get a cabinet or chair underneath. Good Luck! -- Mike |
#4 posted 185 days ago |
That’s a great bench design as is. I’d not mess with it. You could always have your chair at the vise end. -- He who dies with the most tools... dies with the emptiest wallet. |
#5 posted 184 days ago |
Thanks for the advice, everyone. I think I’ll build this bench as is with some built in drawers and another one of a different design for craft/electronics work. |
#6 posted 184 days ago |
I’ve had that bench, and it’s a great one, but really relies on those stretchers to keep it from rocking for handtool type work. If you only plan on using this for powertool type work, and/or light electical/crafts than you could potentially forgo the front lower stretcher to accommodate a chair/rolling cabinets. -- ㊍ When in doubt - There is no doubt - Go the safer route. |
#7 posted 184 days ago |
You could always try it without the front stretcher and see how it works. I would defiantly keep the top front stretcher. If it was not sturdy enough you could try adding a stretcher in the center (half way from front to back). Do you need the workbench portable? If not, could you screw all four legs to the floor? -- Jesse, Saint Louis, Missouri |
#8 posted 184 days ago |
Relocate the front stretcher back 1/2 the distance. The bench will still be rigid enough and you will have enough room for a chair. |
| Forum | Topics |
Woodworking Skill Share
8848 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15984 |
Hand Tools
2102 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6135 |
