Festool
« back to Hand Tools forum
Forum topic by Fritz posted 152 days ago 427 views 0 times favorited 7 replies Add to Favorites Watch
View Fritz's profile
Fritz
5 posts in 198 days
152 days ago
Hello if you have a festool domino how do you like it?
Thanks Fritz
7 replies so far
View Dan Lyke's profile
Dan Lyke
1365 posts in 2290 days
#1 posted 150 days ago
Absolutely love it. I now have a way of connecting any two pieces of wood, quickly and simply, all I have to have is a flat spot on both.
Can you maybe be a little more specific about what you want to accomplish with it?
Basically, it makes floating mortises quickly and easily. More axes of constraint and more wood than biscuits. No setting up router jigs to try to cut mortises. Easy referencing to any flat edge.
If your goal was doing edge-banding or joining long edge to long edge, stick with biscuits ‘cause they have a little more room to move side-to-side. For anything else, the Domino rocks and is a very often used tool in my shop.
View AandCstyle's profile
AandCstyle
635 posts in 422 days
#2 posted 150 days ago
I would buy one if I could justify the expense.
-- Art
View live4ever's profile
live4ever
981 posts in 1175 days
#3 posted 150 days ago
Absolutely love it.
View MJCD's profile
MJCD
348 posts in 536 days
#4 posted 150 days ago
An excellent tool, but you need to have a lot of use to justify the price. If you’re serious about woodworking; do a lot of projects which require this type of joinery; then, it’s a great purchase. If you’re a hobbyist who occasionally builds fine furniture (and you don’t want to do biscuits or pocket joints), then the price/functionality equation is quite different.
There are several tangible advantages – the tenon is narrower than a biscuit, and can be used in many more places; it’s significantly stronger, and can be used in a precise environment.
Again, you need to use this tool a lot for it to be more than ‘nice-to-have’.
MJCD
-- Lead By Example; Make a Difference
View NiteWalker's profile
NiteWalker
1462 posts in 742 days
#5 posted 150 days ago
I don’t have one, and generally think festool is overpriced, but I want a domino badly.
View MJCD's profile
MJCD
#6 posted 150 days ago
You need a strong shopvac to support dust & chip removal – the tool expects this, and you’ll get less satisfactory results without one. By-and-large, I consider it a really good purchase. IMO Festool is over-priced when compared to equivalent Bosch tools; however, the Domino is revolutionary.
MJCD
View waho6o9's profile
waho6o9
2876 posts in 742 days
#7 posted 150 days ago
http://www.senecawoodworking.com/
Accessories for the Domino like the Domino plate above, make it a truly
incredible machine, one side is for joining 3/4” material and the other side is for
joning 1/2” material, on center and in the middle every time.
90 degrees flush is awesome.
Love my Domino.
