frame for sliding cabinet doors?
Forum topic by mzimmers posted 185 days ago 587 views 0 times favorited 8 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
72 posts in 2113 days
185 days ago
Topic tags/keywords: cabinet sliding doors frame
Hi, all -
I’m getting ready to build some cabinets for the garage. Nothing fancy; just a 6’x4’ plywood box with a bunch of shelves. But, as tight as space is, I was thinking of going with sliding doors instead of swingers.
So…good idea/bad idea/other? I was envisioning building a frame, possibly out of 2×4, to accommodate the tracks. But it seems like overkill, and I’d be concerned about the strength (this cabinet will be hanging, so the frame has to support the doors’ weight.)
A semi-related question: what tool/technique would you use if you wanted to take a 2×2 and turn it into a wooden L-bar? Say, relieve a 3/4” square from one corner. I could see doing this with a largish router bit, but…it seems like that’s removing a heck of a lot of wood for a router.
Thanks…
-- M. Zimmers, central CA
8 replies so far
858 posts in 691 days
#1 posted 185 days ago
Sliding doors are a great way to save space that swinging doors need. I’ve done them several times, and simply cut my own tracks out of a very hard unknown species wood I had. The grooves were only 5/16” wide becasue I used 1/4” plywood for the doors. The was just about thick enough to use some recessed brass pulls I found at Lowes. I cut a 2” hole and the pulls fit right in, projecting out the back of the door by maybe 1/16”. 1/4” ply isn’t real stiff, and it does get a slight bow across the height, but this is for shop and garage cabinets, and I didn’t care. Even if you made them out of thicker ply, the weight shouldn’t be a problem for frame. Heavier doors may not slide so smoothly due to the weight, but I’d guess you could put some of that UHMW tape in the lower groove if need…maybe even paste wax would be enough if it’s a problem. Just remember to make the upper grooves much deeper to allow slipping the door in/out of the track.
-- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard)
View Ben's profile
Ben
152 posts in 1055 days
#2 posted 185 days ago
as for the 2X2 to L-bar – two passes on the table saw should easily handle that…
mzimmers
#3 posted 185 days ago
1/4” for the doors? Didn’t they warp like crazy? I’ve had lousy luck with any plywood less than 3/4” and warpage.
I guess you’re right, though…you’d want the doors to be light if they’re sliders.
What did you use to cut the tracks? Router or dado?
View CliffSCCA's profile
CliffSCCA
15 posts in 376 days
#4 posted 185 days ago
Shopnotes Issue #77 had a cabinet with sliding doors in it. It was basically a rail and stile door frame with 1/4” pegboard panel. I assume you could use 1/4” ply instead. The track was made from a strip of 1/8” aluminum bar set in a dado on the bottom. They used sliding glass door rollers recessed in the bottom of the door panels to make it slide. It’s not air/dust tight, but it seals up fairly nice. Here is a link to the Online portion http://www.shopnotes.com/issues/077/extras/sliding-door-shop-cabinet/ and if you need a digital copy of the issue, shoot me a PM and I can send it to you.
-- Mmmm....sawdust
mzimmers
#5 posted 185 days ago
Thanks, Cliff, but it let me download a copy, so I’m good. Interesting idea to use a metal insert.
I’m still pondering the merits of 1/4” wood for the panels, though; I can just picture them warping like mad.
89151 posts in 1775 days
#6 posted 185 days ago
I’ve used 1/4” ply for flat panels for years and never had a problem. They hardly have room to move with all four edges in grooves.
mzimmers
#7 posted 185 days ago
“as for the 2X2 to L-bar – two passes on the table saw should easily handle that…”
Yes, it would…if I had a table saw. I can borrow one, but I was just curious what people thought of removing so much material with a router. This will be a hardwood, too, though not maple or anything crazy hard.
View jumbojack's profile
jumbojack
709 posts in 822 days
#8 posted 185 days ago
5 or 6 passes on your router table will take care of the L shaped 2×2 for sure.
1/4” ply or MDF for the panels. I’ve never had one move on me.
