Hey Lathe people ! (turning questions)
Forum topic by GaryW posted 12-16-2012 03:42 PM 1916 views 0 times favorited 9 replies Add to Favorites Watch
View GaryW's profile
GaryW
125 posts in 2605 days
12-16-2012 03:42 PM
Topic tags/keywords: question
I just got a 12×36 lathe.
Can I turn cedar bowls or any type of cedar ?
Does the 12 mean I can turn a 12in bowl ?
-- GaryW, Edgefield SC, Too old to start over, can't remember why...
9 replies so far
View RVroman's profile
RVroman
163 posts in 2166 days
#1 posted 12-16-2012 04:14 PM
I have turned red cedar without a problem, not sure about other types, but I cannot imagine why you could not. As far as turning a 12 inch bowl with a 12 inch swing, sort of. You can start with a [close to] 12 inch blank, but due to the shaping your final result will be less than 12”.
-- Robert --- making toothpicks one 3x3x12 blank at a time!
View JollyGreen67's profile
JollyGreen67
1676 posts in 2905 days
#2 posted 12-16-2012 06:58 PM
The 12” is the distance from the center of the head stock to the bedway. It does not include the top of the banjo, which is of different thicknesses on each type lathe. So, subtract the banjo thickness from 12” and this will be maximum size to turn. I have turned red cedar often, it is really soft, your tools must be really sharp to prevent tear-out. It will also generate LOTS of red dust that gets into everything, wear a mask even if you have a DC !
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
View MonteCristo's profile
MonteCristo
2099 posts in 2330 days
#3 posted 12-17-2012 12:23 AM
If you can spin it, you can turn it ! Watch the speed.
View RussellAP's profile
RussellAP
3104 posts in 2428 days
#4 posted 12-17-2012 12:32 AM
Most 12×36 don’t come with a chuck for turning bowls. You have one?
View mikema's profile
mikema
180 posts in 2728 days
#5 posted 12-17-2012 12:43 AM
12” is the maximum diameter you can turn on the lathe. So the center of the drive spur to the bed is approx. 6”.
Cedar is very commonly used on the lathe. As with anything, keep your turning tools sharp.
-- Mike ---- Visit my woodworking blog: http://sawdustnewbie.com
JollyGreen67
#6 posted 12-17-2012 03:18 AM
GaryW – I misspoke, mikema has the correct dimensions, 6” from the center of the drive spur / head stock to the bed. So, just under 12” , probably 11-3/4 is about max if the banjo is not under the object to be spun.
View Wildwood's profile
Wildwood
2422 posts in 2276 days
#7 posted 12-17-2012 02:28 PM
Swing over the ways and tool rest base always limit size of bowl blanks can turn. You know from previous post swing over the ways is 6” for your lathe. We do not know the height of your tool rest base on you lathe. Some owner’s manuals give you real numbers you can use and some do not.
My manual says 16” swing over the ways & 12” swing over tool rest base, which is not true. Have to mentally take away fractions or inches to be safe. Also, have to watch your placement of tool rest & base. With lathe off always rotate a blank by hand to insure proper clearances over ways, tool rest & base.
No, do not need a 4-jaw chuck to turn bowls; they do make life easier but not always necessary.
-- Bill
View Knothead62's profile
Knothead62
2584 posts in 3103 days
#8 posted 12-17-2012 02:31 PM
Good turning! However….......chucks, tools and accessories will cost a lot more than the lathe. Does the head swivel so larger turnings are possible? I have one like that.
View hairy's profile
hairy
2764 posts in 3674 days
#9 posted 12-17-2012 02:43 PM
Start at your lowest possible speed. The slower the better with a big blank.
-- My reality check bounced...
