Pipe clamp slipping?
« back to Hand Tools forum
Forum topic by 12strings posted 12-15-2012 06:11 PM 5365 views 0 times favorited 10 replies Add to Favorites Watch
View 12strings's profile
12strings
434 posts in 2625 days
12-15-2012 06:11 PM
the movable part of one of my pipe clamps is slipping. It’s one I use a lot, could it just be worn out? or that spot on the pipe not grippy enough? any thoughts?
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
10 replies so far
View teejk's profile
teejk
1215 posts in 2925 days
#1 posted 12-15-2012 07:12 PM
you don’t mention the brand but you could try to re-arrange the “clutch” plates (they come out pretty easy). or swap a few out of another fixture. if still not working, try new pipe (cheap, which defines me).
I’ve only owned Pony’s and I think replacement clutches are available…never needed to look and I’m guessing the cost with shipping would tell me to buy a new clamp.
117418 posts in 3817 days
#2 posted 12-15-2012 07:15 PM
Most of the time I see pipe clamp slip it’s because they have been put together with galvanized pipe. Black pipe is best because the galvanized coating isn’t there to come off .
View poopiekat's profile
poopiekat
4408 posts in 3975 days
#3 posted 12-15-2012 07:27 PM
Maybe if you got those eccentric toothed cam tailpieces, rather than the multiple-disc type, that’s what your problem is. They don’t bite into the pipe anymore after a while, and unless you’re willing to ‘sharpen’ them…they’re goners.
View RussellAP's profile
RussellAP
3104 posts in 2527 days
#4 posted 12-15-2012 07:38 PM
Sand the pipe with some 40g with a ROS. Problem solved, for a while. Jim is right, buy the black pipe next time.
View lew's profile
lew
12512 posts in 3996 days
#5 posted 12-16-2012 05:16 PM
If they are Pony style, with the 3 separate gripping rings, take the movable section apart and reverse (flip over) the rings.
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#6 posted 12-16-2012 05:31 PM
Vise grips work for me.
12strings
#7 posted 12-17-2012 05:01 AM
Thanks for the advice. Unless Galvanized pipes are black, then I am already using black pipes…but the black stuff is scraped off in places.
Update: I took apart the clamps and removed the metal rings, which were gunked up with black stuff. I cleaned them and sanded them and the pipes a little to roughen them up. They hold great now!
(These 2 clamps are my “double-screw Face-vice,” which is why they get used so much)
12strings
#8 posted 03-24-2013 02:47 AM
Update #2…after about a week, the same clamp started slipping again. It may just be a bad clamp (Harbor Freight). It is black pipe, so I’ll probalby try once more to “sharpen” the clutch plates…if that doesn’t work, I’ll have to replace it.
woodbutcherbynight
5837 posts in 2649 days
#9 posted 03-24-2013 02:50 AM
Take a small file and put some teeth in them after you sand with at least 40grit like RussellAP suggested.
poopiekat
#10 posted 03-24-2013 01:42 PM
Oh, I get it, the reason is revealed in #8. Back when money was scarce, I drilled some 3/16” holes in the pipes and stuck a bolt through when the tailpieces couldn’t get the job done any more.
