How big of rabbets on large picture frame??
Forum topic by C_PLUS_Woodworker posted 159 days ago 595 views 0 times favorited 10 replies Add to Favorites Watch
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
203 posts in 1077 days
159 days ago
Topic tags/keywords: oak arts and crafts
Making an Arts and Crafts/Mission-style oak frame. 3” rails and stiles. 20” x 18” inside measurements
How deep and wide should I make the rabbets for the glass and matte?
Also, glass thickness?
Thanks everyone.
10 replies so far
View pintodeluxe's profile (online now)
pintodeluxe
1752 posts in 983 days
#1 posted 159 days ago
I have made several, and in fact am making one right now. I use 1/8” glass, 1/8” matting, and 1/16” backing, so I cut 5/16” deep rabbets. I cut them 1/4” wide, which is plenty to support the glass.
Good luck!
C_PLUS_Woodworker
#2 posted 159 days ago
Thanks, Pinto
I am going to use 2 layers of matte
Is all matte 1/8 ?
View Ted's profile
Ted
1400 posts in 381 days
#3 posted 159 days ago
Seems the thickness of whatever is going into it would be how deep to make it. I’m not sure if window glass is the same, but double strength glass is 1/8” thick. Then there is the thickness of whatever is going into it, and the thickness of the backing, if any. If in doubt, I would tend to make the rabbet 1/4” deep by 1/4” wide. I don’t know if there is a standard for picture frame rabbets. Somebody else can chime in about that.
EDIT: Oops, looks like somebody done chimed in. :)
-- I'll grow up when ketchup bottle farts stop being funny.
View Jimbo4's profile
Jimbo4
712 posts in 933 days
#4 posted 159 days ago
Rabbit is normally 1/2” wide
Depth of rabbit depends on how many mats will be used, backing and, thickness of object to be framed.
For that size frame, single pane glass is ok.
( ex professional framer )
-- *Arachnoleptic*: The frantic dance performed just after you've accidently walked through a spider web.
C_PLUS_Woodworker
#5 posted 159 days ago
Ted and RoseBud…........always glad for input….............thanks.
Rick Dennington
2889 posts in 1364 days
#6 posted 159 days ago
Hey bud,
When I do picture frames (which is not often), I usually make the rabbit 3/8” deep, and 3/8” wide…..that will give you enough “lip” for the glass and mattes, plus a smigin for a small brad…...hopes this helps a little….
-- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!!
Jimbo4
#7 posted 159 days ago
Just my two cents: Matte is french for the english version of mat. Matte is also a kind of glass with frosted finish, normally non-reflective.
View Ted's profile
Ted
#8 posted 159 days ago
I think it boils down to whatever works for the given situation. I’m glad to know that 1/2” width is the professional standard. When in doubt, I will stick with what the pros do. 3/8×3/8 is also a good dimension. For a narrower frame, 1/2” might be too much.
On the few occasions I made frames, they have been built for a specific piece. The depth and width of the rabbet was dictated by that piece, plus the glass, and the backing, or matte, or mat… I think we all get the idea. Whatever works is the best way to go.
87234 posts in 1747 days
#9 posted 159 days ago
Ditto on the every option is different if as an example if your going to put a framed canvas painting in a picture frame then you need a larger rabbit say 1/2×1/2” where a 1/8th in glass with matting may only need half of that.
C_PLUS_Woodworker
#10 posted 158 days ago
Thanks Guys…............really appreciate the guidance…...........and I love this site!
