Wooden Dominos
Forum topic by DonJ posted 12-14-2012 08:05 PM 6455 views 0 times favorited 11 replies Add to Favorites Watch
View DonJ's profile
DonJ
250 posts in 3400 days
12-14-2012 08:05 PM
I saw the following domino set at a recent furniture show in Kerrville, TX:
The only templates I’ve been able to find are from Rockler. Has anyone used this set of templates before and if so, any lessons learned? Also, what paint did you use and how did you apply it? The picture above appears to have really uniform dots throughout. Any help would be appreciated. Thanks so much.
-- Don, San Antonio, TX
11 replies so far
View mtenterprises's profile
mtenterprises
933 posts in 2565 days
#1 posted 12-15-2012 12:15 AM
I made a set of dominos years ago and made my own template out of aluminum just lay out 7 holes the size you need. Now for the dots, or pips as they are called, I took a dowel that fit into the holes in my template chucked it into my drillpress set it at high speed and “burned” in each pip. On dark wood you would have to use a white paint after burning the pips in. A tooth pick dipped in the paint should properly drop enough paint to fill the indentation. When the paint is fully dry then you can sand off any excess then use your favorite clear coat to finish.
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
View Steve Peterson's profile
Steve Peterson
362 posts in 2955 days
#2 posted 12-15-2012 12:56 AM
I don’t have much advice, but it seems like it might be relatively easy to make a drill press jig to drill one hole and add 1 or 2 spacers in the X direction and 1 or 2 spacers in the Y direction to drill all the other hole positions. The spacer could be twice as wide as it is tall so you either lay it flat or stand it on end for the 2 sizes. This would work great if you cut the dominoes first.
You could try using a 3/16” ball end mill to drill the holes. This would give a better profile than a normal drill bit.
Fill the holes with a good quality paint. Then sand the tops to get good crisp lines. You may need to experiment with sealers before the paint to keep it from bleeding.
-- Steve
View dannelson's profile
dannelson
188 posts in 2244 days
#3 posted 12-15-2012 01:25 AM
Are you looking for a jig? I have a file written already for my cnc. A few weeks ago I made one up for a local guy. When I made mine I did it out of walnut for the base and the pips from maple dowel, the next set i would like to use brass or aluminium for the pips
-- nelson woodcrafters
View gfadvm's profile
gfadvm
14940 posts in 2563 days
#4 posted 12-15-2012 02:48 AM
Fellow LJ staryder has posted several domino sets and boxes for them and they are BEAUTIFUL! I think he would be the best source of information for all things domino! If he doesn’t weigh in you might send him a pm.
View waho6o9's profile
waho6o9
8070 posts in 2449 days
#5 posted 12-15-2012 02:54 AM
http://lumberjocks.com/projects/73296
Lumber Jock Staryder made these fine dominos.
View staryder's profile
staryder
173 posts in 1912 days
#6 posted 12-15-2012 01:46 PM
Thanks guys for the segway that was extremely kind of you to do…. I responded to Don to give him some direction to go in. I have been working to prefect my methods of making them a couple of years and would like nothing better than to help Don shorten that journey so he can knock out a set for his kids.
-- Rick.... Fort Worth, Texas
waho6o9
#7 posted 12-15-2012 02:14 PM
Thank you for the continuity Rick!
View Philip "Pip" Storm's profile
Philip "Pip" Storm
130 posts in 2208 days
#8 posted 07-31-2014 11:06 PM
Hey staryder, would you care to give me some of that direstion you gave Don? I’d like to make a few sets for xmas gifts.
-- Well, I'll be screwed, glued, and tattooed!
View Tatteredshoelace's profile
Tatteredshoelace
2 posts in 947 days
#9 posted 06-17-2015 06:32 PM
Not sure if anyone will see this, but since I can’t send PMs yet I’m hoping dannelson will see this and message me his CNC file so I can have a jig made up.
View robscastle's profile
robscastle
4713 posts in 2077 days
#10 posted 06-18-2015 02:01 AM
Don I made a perspex jig some time ago for a set of ebony Dominos.
If its of interest let me know and I will go find it for you to take a look at.
-- Regards Robert
Tatteredshoelace
2 posts in 947 days
#11 posted 06-18-2015 03:34 AM
I’d like to see it
