| Forum topic by RWininger | posted 158 days ago | 780 views | 1 time favorited | 5 replies | ![]() |
158 days ago |
Ok, so I spent way too much time last night looking for some sort of formula, if there is one on whole placement on a Gravity wine bottle holder. I would think you need to take into consideration all dimension of the board? Any help |
5 replies so far
#1 posted 158 days ago |
Here are the dimensions I used:
Depending on your hole size and cut angle, the 5-7/8” dimension will change. The best thing is to make a test piece first from scraps. Just to start somewhere and adjust until it works. I found it really wasn’t too difficult. -- Rex |
#2 posted 158 days ago |
If you search wine balancers here, you’ll fine several different formulas. Part of it is if you want the bottle held level or not. I know Jim Jakosh just recently posted his formula as well. -- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability |
#3 posted 157 days ago |
The best and quickest way is to use trial and error. With all the different size bottles, it would be difficult to pin down specific dimensions. I assume you want the bottle to be neck down to keep the cork wet? |
#4 posted 157 days ago |
Ideally, if you make the hole large enough to slide the bottle in and out and buy a bottle that has a couple inches of play that is fairly straight, 45 degree’s will balance. Sneak up on it. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#5 posted 156 days ago |
Yes there are good formulas on the net but for level this is mine… http://lumberjocks.com/projects/13508 -- Never board, always knotty, lots of growth rings |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1531 |
3547 |
15771 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2839 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
