Bandsaw Riser Block and Blade Guide Question
Forum topic by Ted posted 12-14-2012 06:20 AM 1572 views 0 times favorited 13 replies Add to Favorites Watch
View Ted's profile
Ted
2847 posts in 2211 days
12-14-2012 06:20 AM
Looks like I might be able to squeeze a decent bandsaw in to my budget pretty soon, and I’d like to get a decent resaw capacity. One that is built with 10” or 12” depth of cut will probably not be within budget, so I’m thinking one that will accept a riser block. What I’m wondering, however, is how does one compensate for the height adjustment of the blade guide. I mean, if the riser block adds, say, 4” to 6” to the depth of cut, wouldn’t the upper blade guide have to be modified accordingly? Also, would the cost of that, along with the riser block, end up costing so much I could just buy the bigger saw to start with?
-- You can collect dust or you can make dust. I choose to make it.
13 replies so far
View Pete_Jud's profile
Pete_Jud
424 posts in 3752 days
#1 posted 12-14-2012 06:29 AM
I added a 6 inch block to my delta 14. It came from delta via or amazon, under a hundred bucks, and came with all the parts to make it safe. So now I can rip up to 11 7/8 on it.
-- Life is to short to own an ugly boat.
View Ted's profile
Ted
#2 posted 12-14-2012 06:34 AM
Thanks Pete. By “all the parts to make it safe”, is that to say it comes with parts to modify the blade guide height adjustment slider thing? Sorry, I don’t know what it’s called :)
View David Craig's profile
David Craig
2137 posts in 3108 days
#3 posted 12-14-2012 06:43 AM
I purchased a 14 inch grizzly and the riser kit. The riser kit included a replacement height adjustment bar for the upper blade guides and the blade guard so that height was completely adjustable from high to low. I believe most riser block kits include this Ted.
View Jim Jakosh's profile
Jim Jakosh
20488 posts in 3105 days
#4 posted 12-14-2012 01:22 PM
I have the Grizzly G0555 saw and they sell a 6” riser kit that comes with the steel riser, the longer blade guards for the right and left sides and a longer (105”) blade. I made the one for mine and I just don’t have the longer blade guard on the right side. I have exposed blade above the regular guard but never get near there. I have resawed 11” maple on there with a 1/4-10 pitch blade. It is a nice saw, I love it!!
View Ted's profile
Ted
#5 posted 12-14-2012 03:51 PM
Thanks for the info, guys. I guess it only makes sense the riser would come with the blade guard, but I needed to hear (read) it from someone who knows.
View waho6o9's profile
waho6o9
8191 posts in 2576 days
#6 posted 12-14-2012 04:03 PM
Carter bearings help with deflection of the blade and was
a great addition to my old band saw.
I know this doesn’t answer your question Ted but it’s something
you might want to consider. Good luck on your purchase and you’re
going to love having a decent band saw.
View vonhagen's profile
vonhagen
534 posts in 2364 days
#7 posted 12-14-2012 04:37 PM
ted go to woodweb and check out the machine listings, you could find an old oliver or northfield my other choice would be a rockwell 20. my davis and wells 20 is awesum but hard to find. as far as blades i only use 2 the starrett woodpecker and the lenox trimaster. not a big fan of carter guides on these late model machines because the originals are much better when rebuilt but they are so well built that you may find they are just fine. you will notice that on all these older machines that there is only one bearing on the rear at 90 degrees to the blade and carbide inserts on the sides and this is the best system imo, time tested, mine are 60 years old and i just pressed in new bearings from davis and wells and replaced the carbide blocks with new ones. i think it was about 60 bucks and the saw cuts like a dream. as far as bandsaws go bigger and older is better.
-- no matter what size job big or small do a job right or don't do it at all.
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2856 days
#8 posted 12-14-2012 05:38 PM
Ted, have you ever thought about a build?
http://woodgears.ca/bandmill/index.html
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View b2rtch's profile
b2rtch
4861 posts in 3048 days
#9 posted 12-14-2012 05:47 PM
I bought my riser block kit from HF ,and it came with every necessary parts.
-- Bert
View Surfside's profile
Surfside
3389 posts in 2173 days
#10 posted 12-14-2012 05:56 PM
Carter riser kits are great for the bandsaw.
www.bandsawblog.com
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View DS's profile
DS
2917 posts in 2420 days
#11 posted 12-14-2012 06:36 PM
I found my 19” Shop Fox BS on craigslist for $400 in decent shape. I see the big ones for sale about once or twice a year in Phoenix. If you have patience, that would be the way to go.
The larger footprint in my garage shop isn’t much more than the 14” machine anyway. It cuts large stock like a dream too. A 143” blade has plenty of time to cool down the teeth between strokes and so deflection and heat is never an issue.
My Dad has a Delta 14” BS and he comes to my house to use my 19” BS when he wants to resaw anything serious—if that tells you anything.
Of course, I go to his house to use his Jet 1642EVS lathe to turn anything substantial—it works out.
View dhazelton's profile
dhazelton
2767 posts in 2296 days
#12 posted 12-14-2012 06:45 PM
I have an older Delta with riser and two speed gearbox (for metal or wood cutting) that I paid $60 for. A good tool is always within budget if you snoop around and aren’t in a huge hurry.
View Scomel Basses's profile
Scomel Basses
169 posts in 1996 days
#13 posted 12-15-2012 01:31 AM
I tried to start a new thread with my question but I couldn’t. Maybe I’m too new but either way this is probably a good thread to ask it in.
I currently have a Grizzly 555LX that I like very much. I generally never resaw over 5 or 6” and this saw does it with ease, much better than an old Delta I used to have. Occasionally I may have a need to resaw 7-8” boards and will need the riser kit. However I’ve heard some folks dislike riser kits on 14” saws because they feel the frame isn’t up to the task of the extra tension the longer/wider blade requires and wheel alignment issues. Anyone have any experience with this saw or have opinions in general about riser kits?
