End Grain Butcher Block Counter Top
Forum topic by doninvegas posted 159 days ago 449 views 1 time favorited 1 reply Add to Favorites Watch
View doninvegas's profile
doninvegas
311 posts in 1076 days
159 days ago
We are remodeling our kitchen including granite counter tops. Our kitchen island which is 24” X 48” where we will be installing a Maple end grain butcher-block. This will be used as a cutting board a lot. Since this will be near the sink and have dishes, pots and pans etc. I decided to finish it with Waterlox. I wanted something more durable then the salad bowl oil that I use on my regular end grain cutting boards. My question is, how many coats should I apply? The underside will be over the dishwasher with a vapor barrier in between. I think that side should have extra coats?
Thanks,
-- "Courage is being scared to death -- but saddling up anyway."
1 reply so far
View CharlesNeil's profile
CharlesNeil
855 posts in 2039 days
#1 posted 158 days ago
Usually , Waterlox will build a nice finish in 3 or 4 coats, , end grain 5 may be required, at the point you have a nice sheen , your done. Waterlox does quite well, and is durable. In the world of finishes , more doesnt mean better.If you were doing a set of steps where traffic wear and so forth existed, then a few xtra coats would be fine, but in a normal application, not the case, heavier films are more prone to break down than thinner films. if you have 3 or4 coats your good,
