How to repair a cracked wood table top surface?
Forum topic by BubTheBuilder posted 12-13-2012 09:19 PM 5556 views 0 times favorited 4 replies Add to Favorites Watch
View BubTheBuilder's profile
BubTheBuilder
58 posts in 2421 days
12-13-2012 09:19 PM
Topic tags/keywords: pine finishing repair
So I have been pondering the solution to this question for a few weeks now. Needless to say I have yet to come up with an answer that I am convinced will work. I figured the best thing to do is to reach out to the seasoned veterans of LJ.
So here is what I have going on. A large crack is forming on a pine table top. It does not go completely through to the bottom, but it is expanding out to make the crack longer. It is about 1/4” deep and 6” long.
I do not feel that this is a simple wood putty filler solution because it is so deep. Are there any other options here to fill the hole and keep this from growing? I was thinking some liquid nails in the crack and then filler on top of the liquid nails to seal and stain it. I thought about shellac maybe? But then the problem is matching up the stain. I would also hate like hell to have to tape it off, sand it down, fill it, stain it and poly it all while trying to match the current finish. If I have no choice, then I have no choice.
Any thoughts or solutions to this problem would be greatly appreciated. Thank you, Happy Woodworking & Holidays.
-- Richard-- "If it ain't tight, then it ain't right."
View bondogaposis's profile (online now)
bondogaposis
5056 posts in 2529 days
#1 posted 12-13-2012 10:07 PM
First you have to figure out why it is cracking. A picture would help.
-- Bondo Gaposis
runswithscissors
2875 posts in 2203 days
#2 posted 12-13-2012 10:36 PM
One possibility would be to fill the crack with beeswax. Since the crack may continue to grow, you can add more wax as needed. The wax is already a honey tan color. If your pine is stained darker, you might be able to darken the wax as well. Don’t know how—trial and error would be my approach. The softness of the wax should allow the wood to move at will, because it’s possible it might try to shrink back together (not so likely, I guess).
View Clint Searl's profile
Clint Searl
1533 posts in 2539 days
#3 posted 12-17-2012 01:08 AM
Pull it together with glue and clamp.
117283 posts in 3755 days
#4 posted 12-17-2012 03:25 AM
I’m with Bondo find out why it’s cracking in could be a wood movement problem. Do you have a photo of the table top and bottom?
