Wet saw
Forum topic by snowdog posted 461 days ago 197 views 0 times favorited 7 replies Add to Favorites Watch
View snowdog's profile
snowdog
809 posts in 882 days
461 days ago
Topic tags/keywords: wet saw
Ok I know this is not wood working but I was hoping someone might have an opinion on what I should get.
I am doing my front entrance (pavers about 1 1/4 inch thick), a few concerns are :
1) storage – another tool that has to be stores (I dont want to rent it :)
2) Cost vs preformace
3) I hate crappy tools
This is the one I am thinking of getting :
$189
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100569361
Or
$159
http://www.sears.com/shc/s/p_10153_12605_00928105000P?mv=rr
Here are a few others I was looking at:
$299
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100557928
$79
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=40315
$98
http://www.lowes.com/lowes/lkn?action=productDetail&productId=124503-1255-60087&lpage=none
$88
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&langId=-1&catalogId=10053&productId=100074675
View NY_Rocking_Chairs's profile
NY_Rocking_Chairs
435 posts in 497 days
461 days ago
Usually when I see the DIY shows on HGTV they are cutting pavers with a simple angle grinder or a concrete chop saw. Since they are only 1 1/4” thick, you can probably get away with just the angle grinder, and it will give you more control and options in shaping the pavers.
-- Rich, WNY, www.nyrockingchairs.com
View Tim Pursell's profile
Tim Pursell
392 posts in 682 days
461 days ago
I layed 6,374 pavers in my driveway about 8 years ago. I was helped by a neighbor who is an old brick layer/stone mason that had a huge old overhead track brick saw. We never touched the big saw. We made every cut with a dry cut diamond blade (expensive) in an old (cheap) circular saw.
You really do not need to buy (& then store) a wet saw, or even a “specialized” saw for cutting pavers. They cut easily. plunge cut freehand, get close to 1/2 way thru & whack off the waste with a hammer. If needed, dress up the cut with the saw. Buy yourself a DRY diamond blade that fits an old (or CHEAP new one) circular saw & have at it! The reason for using an old/cheap saw is the stone dust will ruin the brushes &/or bearings. you will get thur this job & a couple more, but the saw will die SOON.
-- http://www.grandprairiewoodworks.com http://www.etsy.com/shop.php?user_id=6453794
NY_Rocking_Chairs
461 days ago
Come to think of it…
I used a cheap dry diamond blade to cut 3/8” slate tile for our kitchen and craft room. I cut all those on the table saw and it help up just fine.
View CoolDavion's profile
CoolDavion
215 posts in 724 days
449 days ago
Depending on how crisp you want the cuts, you could always just use a brick set (chisel).
  • Lay the paver on a board on a flat hard surface driveway or garage floor.
  • lightly tap the set on all four sides to score where the cut will be.
  • tap on the top going all the way across the cut line from one end to the other untill the paver breaks in two
Other option
  • lay all the full pieces first.
  • Mark all of the cuts you will need
  • Then rent a saw and make all of the cuts. (shortest amount of time)
I worked for a landscaper in collage. So there is some experence to the above
-- don't sweat the petty things and don't pet the sweaty things
View RAH's profile
RAH
413 posts in 776 days
449 days ago
I use a dimond blade on a circular saw to cut roofing tiles. Buy a cheap one about $15.00 and give it a try.
-- Ron Central, CA
snowdog
449 days ago
To followup on this project I used my old (25 + year old) portable table saw with a diamond blade, no fence, just a free hand cut on 16×14 x 1.5 inch concrete irregular shaped paver.
http://im1.shutterfly.com/procgtaserv/47b8d725b3127cce985488d410e200000046100AZs2zFq2btmKg
My wife and I are very happy with the results. It cut like butter ( well not really but it was much easier than expected).
Thank you all for your suggestions and comments it helped a lot.
As with any project, if anyone is reading this and wants my thoughts please post em and I’ll give you any help I can.
View roman's profile
roman
1125 posts in 793 days
449 days ago
Buy Once
Cry Once
never cry again
