Sparks when vacuuming sawdust
Forum topic by jaidee posted 12-13-2012 04:33 PM 1634 views 0 times favorited 4 replies Add to Favorites Watch
View jaidee's profile
jaidee
51 posts in 2744 days
12-13-2012 04:33 PM
Hi Y’all,
In my garage shop I was cleaning up after a short cutting project. I use a Vortex bucket connected to my shop vac to extend the life of the HEPA filter. While vacuuming up a small pile of sawdust I started getting static shocks and noticed small static electric arcs appearing along the hose. I know that this is not a good thing and that is why dust filtration systems are heavily grounded. But I don’t have the room or money for a dedicated filtration system. For now I am using my shop vac/Vortex hooked up to each machine as I use it to keep the dust down. I haven’t noticed this problem when it’s hooked to a machine but I’m not usually watching it while I’m cutting/routing/jointing, etc. Any thoughts on how I can ground this set-up so I don’t wake up in the hospital burn unit some day? Thanks in advance for your thoughts…...
jd
-- I used to be all thumbs......'til I got a tablesaw!
View Bill White's profile
Bill White
4902 posts in 3925 days
#1 posted 12-13-2012 04:45 PM
This may sound a little goofy, but I put a couple generic clothes dryer “softening” sheets through the vac hose letting ‘em stay in the canister. Add new ones when I empty the vac. Stops static just like in the clothes dryer.
Just another mindless shop tip from the White Book of Barnyard Senseless Stuff.
Bill
-- bill@magraphics.us
jaidee
#2 posted 12-13-2012 07:05 PM
Hey, I’ve seen goofy work before so I’m not above trying goofy. Thanks for the tip, I’m gonna try it tonight.
jd
View ajosephg's profile
ajosephg
1880 posts in 3526 days
#3 posted 12-13-2012 11:18 PM
Other than the discomfort the shock gives, there is no danger of starting a sawdust fire. This has been extensively blogged and researched.
-- Joe
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2037 days
#4 posted 12-13-2012 11:32 PM
many dust collection hoses are coiled with steel so you can ground them. Assuming the vortex bucket is plastic it may have “insulated” your system. connect a ground wire between the hose entering the vortex and the dust collector or hose connecting to the vacuum groud.
sorry need to read better…. add a ground wire from the vac hose to vac.
i am curious… did the dryer sheets work.
-- Who is John Galt?
