Forum topic by jaidee | posted 12-13-2012 03:47 PM | 1158 views | 0 times favorited | 8 replies | ![]() |
Hi Y’all, I’m finally making that kitchen island that was my first Sketch-Up design and I’m having some difficulty with the cutting phase. The sides, top and bottom are cut from 3/4” MDO and the face frame for the cabinets is being constructed from 3/4”x2” (actual) Poplar as it is going to be painted. My question is on the stiles for the face frames. I’m using mortise and tenon joinery and they will have a 1/4” bead on the inside edge (around the door/drawer openings – inset flush doors). I know this isn’t the easiest way to do it but I want to try something different and like the idea of the bead not being an add-on after the fact. So here’s the question: Since the bead is on the same side of the stile as I have to cut the mortise, do I cut the mortises in the stiles first or do I rout the bead first? I’ll be using my router table to mill the bead and a mortising attachment on my Grizzley drill press for the mortises. I know I could waste some stock and experiment myself but I have just enough Poplar on my racks to do the job and don’t want to have to make another trip to the lumber yard for one piece. I appreciate your thoughts on this….... Thanks, jd -- I used to be all thumbs......'til I got a tablesaw! |
