| Forum topic by bbasiaga | posted 188 days ago | 552 views | 0 times favorited | 13 replies | ![]() |
188 days ago |
Topic tags/keywords: question Hi all. I’m new to Lumberjocks and fairly new to wood working as well. Thus far, I have designed and built a lo of plywood stuff, with my main masterpiece being a collapsible large diameter telescope. Now I’m wanting to expand in to some actual furniture for the house, and using some hardwood. I’m thinking my first project will be some end tables, and eventually a matching coffee table. The wife and I seem to like shaker style, and we’ll probably do some adaptation of that. There is a wood workers store here that has a lot of hardwood choices, mostly 4/4 but some up to 8/4, all finished on 3 sides. Its quite pricey but they are the only thing in the area. I have shared custody of a table saw, benchtop band saw and router table, a number of hand tools. I plan to add a planer and jointer very soon. I guess what I’m asking for from the group is some advice on things to think about when drawing/planning the project, and any things I should consider when for working with solid hardwood for the first time. Are there any special tools or other things I may need that I don’t have listed above, or that aren’t typical household power tools? Thanks, -- Part of engineering is to know when to put your calculator down and pick up your tools. |
13 replies so far
#1 posted 187 days ago |
With what you have and plan on adding you should have more then enough, I assume you have a drill of some sort as well. Drill presses are nice but a basic drill will accomplish most of your needs with care taken to line everything up. Only thing to think about when drawing the plans are that you allow for wood movement. with ply you could screw down a large tabletop all the way around and everything would be fine, with hardwoods you’ll get splitting or warping in a 12”x12” top that doesn’t allow for movement. The only thing besides that is have fun and be creative. Also check craigslist for wood, you’d be surprised how many small mills operate selling air and kiln dried lumber for those willing to do the leg work. -- --Rev. Russ in NY-- A posse ad esse |
#2 posted 187 days ago |
Dude…I wanna see the telescope!!! Welcome to LJs!!! -- jay, www.allaboutastro.com |
#3 posted 187 days ago |
Regarding the project, it really depends on your approach to joinery. In a shaker build, your joinery can certainly be innovative, but likely wont be ostentatious. You can even make it mostly concealed. This means you can use fasteners as opposed to doing traditional mortise and tenon, dovetails, or whatever. This, of course, affects your design and your cuts…as well as your tooling. -- jay, www.allaboutastro.com |
#4 posted 187 days ago |
Plywood can work well as a starter wood. The big box stores have iron on edge banding in birch and is stain-able if you want. Also, go to your local lumber yard and see if they have off-cuts that you can have/buy for a reduced price. Everybody starts somewhere, paying big dollars for wood is a hard way to learn. Do you have clamps – you will need a bunch in all sizes. One thing I did early on, I bought a bunch of Rockler’s 3/4” pipe clamps – went to Home Depot and bought 3/4” iron pipe of various lengths. You only need threads on one end so I had them all cut in half. I have seven or eight clamps and about 2 dozen pieces of pipe at different lengths – always available. Just a thought Welcome to LJs -- David in Damascus, MD |
#5 posted 187 days ago |
Brian, Welcome to LJ’s. As mentioned above, wood movement will definitely be one factor to take into consideration when designing and building with solid wood. Since you like the shaker style, then that would be a good place to start your design. You can always find a set of plans and work from those, or design your own. Besides wood movement; the type of joinery you plan on using will be another factor to consider in your design. If you work from someone else’s plans, then they have already decided for you how you will attach the legs, how you will attach the top, etc. If you start from scratch, them you will need to decide how your table will fit together. What type joinery do you want to use and do you have the tools or capabilities to do a certain type. One of the first books I started with and still refer to today is: Woodworking Joints, an illustrated handbook, by Percy Blandford. I’m not saying it’s the greatest handbook for joinery, but it sure was a great help when I was first learning how to build furniture. A number of my early projects where designed more around joinery, then say a certain style of furniture. I just wanted to learn how to do the different joints. Wood choice will be another thing to take into consideration as well as the type finish you would like to use. Since you’re building an end table, then part of your design process will be; how much wear-n-tear will this piece of furniture have to endure. As you can see, the type of wood, the type of finish and the joinery used should all be part of the design. Over the years I’ve develop my own preference’s of wood or finishes and even joinery that I like to use in each project but that doesn’t necessarily make it the best choice, so those choices I would leave up to you. Good luck and hope you will keep us posted on your progress. -- John @ http://www.thehuffordfurnituregroup.com |
#6 posted 187 days ago |
Wow, lots of responses and its only lunch time! You guys are great. I’ll try and answer some of the questions back to me: - Yes, I have a hand drill and a drill press. So on the joinery issue, I’ve got some limited experience. I’m getting pretty comfortable with biscuit joints, we well as dowel joints. With my new router table, I plan to start practicing a few more joints like slots, rabbets, dados, dovetails, etc. In shaker style furniture, there are typically cross memebers joined to the legs at the top. This forms the box that the table top sits on. From my research and the pieces of furniture I have seen, mortise and tennon construction is pretty popular for those joints. But since that is a fully glued joint, how does the wood expand? Surely those cross members must feel the stress, but are problems avoided simply because they are only 4” or so wide, and therefore don’t expand more than 1/32 or so? -Brian -- Part of engineering is to know when to put your calculator down and pick up your tools. |
#7 posted 187 days ago |
Oh, and I will try and figure out how to set up a ‘project’ here and post some pics of the scope. Hopefully this weekend. -- Part of engineering is to know when to put your calculator down and pick up your tools. |
#8 posted 187 days ago |
Brian: You would be correct regarding that construction…but it doesn’t have to be M&T…it’s just traditional. But regardless of the technique, you can’t keep wood from moving (expansion and contraction). Thankfully, it only really likes to move across the grain, not over the length of the grain. This means that if the sides of a box (like the panels for your table) are constructed and joined with the grain parallel to the ground (and table top), then you don’t have to worry about expansion screwing up your joints. Any movement will be up and down…and only a little bit of it because the boards simply aren’t that wide in the cross grain direction. And because all four sides of the box have the same up and down movement, they move together, not independently. But if you glue the top to that table, you will have issues in that regard because the glue would restrict the movement in the cross grain directions meaning that the table will likely bow and/or twist. So for the top, you have to affix with a few fasteners or “float” it in grooves without glue. This is the reason why your kitchen cabinet doors with its raised panels aren’t glued into the door frames…they float freely. BTW, you can avoid wood movement concerns by using man-made materials like MDF, etc., but that’s often very boring…unless you get creative with veneers. -- jay, www.allaboutastro.com |
#9 posted 187 days ago |
welcome to LJs Brain ,lot of wood masters here to help ya, like to see your telescope too,post some pics ,ive had afew telescopes thoght about make one just to mess with ,last one was a 12 ’’ meade but sold it . -- Jesus Is Alright with me |
#10 posted 187 days ago |
Over the narrow width of a mortise and tenon glue joint there isn’t enough expansion to worry about. Dowels are a fine substitute for mortise and tenon. -- --Rev. Russ in NY-- A posse ad esse |
#11 posted 187 days ago |
Check out projects others have posted. That may give you some ideas how to design and build your project(s). -- Handcrafted by Mike Henderson - Channelview, Texas |
#12 posted 187 days ago |
For those interested, here is the link to my telescope build (mentioned above) which I put up in the ‘projects’ section. -Brian http://lumberjocks.com/projects/75595 -- Part of engineering is to know when to put your calculator down and pick up your tools. |
#13 posted 187 days ago |
Welcome to LJ’s bbasiaga/Brian… Love shaker myself..the biggest worry with Mortise and tenon is getting the joint square and tight…. not so tight you need to beat it in with a sledge hammer, but tight just the same.. -- Papa@papaswoodworking.com |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15978 |
Hand Tools
2095 |
Jigs & Fixtures
501 |
Wood & Lumber
2906 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2776 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
