Best uses for old DeWalt HSS planer blades
« back to Hand Tools forum
Forum topic by derosa posted 12-13-2012 05:36 AM 2990 views 0 times favorited 10 replies Add to Favorites Watch
View derosa's profile
derosa
1590 posts in 3075 days
12-13-2012 05:36 AM
I’ve got one set of old dewalt blades from a 734 planer that are worn out and I’m trying to figure out if they have any real use. I have discovered that HSS is relatively easy to grind in that you don’t have to watch the temperature as much; as long as it doesn’t glow red the temper is unaffected. But I’ve also learned that I don’t have a drill bit that can make a dent in one of the blades; I’m hoping a grinding bit on the dremel will do the job. One thought is a knife, possibly a marking knife though I was thinking a small replacement blade for my folding knife. Any other ideas or thoughts of what can be made with these blades?
-- A posse ad esse
10 replies so far
View lysdexic's profile
lysdexic
5268 posts in 2862 days
#1 posted 12-13-2012 01:59 PM
Russ, what did you put in there place?
-- "It's only wood. Use it." - Smitty || Instagram - out_of_focus1.618
View Bluepine38's profile
Bluepine38
3380 posts in 3324 days
#2 posted 12-13-2012 02:10 PM
If you can heat the tang red hot and have a steel plate with a hole in it and a good punch, you can punch
a hole through those, much easier than drilling or grinding, if you keep the heat away from the blade, you do
not have to worry about its temper.
-- As ever, Gus-the 80 yr young apprentice carpenter
View Darell's profile
Darell
435 posts in 3833 days
#3 posted 12-13-2012 02:11 PM
I see you have a lathe. How about making your own small hollowing tools or a small skew or scrapers? There’s no end to custom turning tools you could make for yourself.
-- Darell, Norman, Ok.
derosa
#4 posted 12-13-2012 02:20 PM
Scottyb- I had to buy new ones, dewalt blades are disposable and mine were pretty hard used for almost 2 years before they went. My understanding is that they really can’t be sharpened.
Gus- Good to know, I can do that and by making the factory hole the one closest to the blade and putting the punched hole the furthest that should be easily far enough.
Darell- I’d thought of turning tools but figured the steel might be too thin and brittle but I’ll give a couple a try.
-- A posse ad esse
lysdexic
#5 posted 12-13-2012 04:13 PM
I ask because I made the bonehead move of planing a screw head with my 735. Having a un-planed ridge on the face of the board isn’t the end of the world as I usually hit the surface with a #7 anyway. Still, I didn’t know if I should try to re-sharpen them, buy new or spring for a helical cutter.
Thanks for the response
View gfadvm's profile
gfadvm
14940 posts in 2929 days
#6 posted 12-14-2012 04:12 AM
Not exactly on topic but I get my “diaposable” Ridgid planer blades sharpened and they cut better than new and seem to last longer. I use Best Grinding in Tulsa, Ok.
derosa
#7 posted 12-14-2012 06:12 AM
It’s a thought, these things sell for 53.00 a set which is a tad high to me but I didn’t think they could be sharpened.
-- A posse ad esse
gfadvm
#8 posted 12-15-2012 01:33 AM
Best charges me $25 a set (3 blades) to sharpen.
View OnlyJustME's profile
OnlyJustME
1562 posts in 2616 days
#9 posted 12-15-2012 01:50 AM
They can be sharpened but as they are sharpened the measurement guides/gauges will be off and need to be reset. Plus if they aren’t sharpened right you could end up with a wavy or uneven (thicker on one end than the other) surface. Eventually you will not have enough blade left to be able to cut the wood since you can not advance the blade as it is in a fixed location on the drum.
-- In the end, when your life flashes before your eyes, will you like what you see?
View BentheViking's profile
BentheViking
1782 posts in 2803 days
#10 posted 12-15-2012 03:16 AM
give yourself a nice shave?
-- It's made of wood. Real sturdy.--Chubbs Peterson
