| Forum topic by RussellAP | posted 187 days ago | 1073 views | 0 times favorited | 25 replies | ![]() |
187 days ago |
I have been making rather clumsy dowel drilling guides for my dowels which is a 90 degree block with three holes or four as drilling guides for the dowel placement. I saw on on line that went for 310$ but I think someone can make one like that for a reasonable price. I can’t pre-drill the wood before assembly, it’s on corners so I need to do it after the glue has been put on and it’s clamped up or even after it dries. What do you use to line up your dowels? I didn’t realize how many different dowel jigs there are. Here is what I need it for. I want to put three dowels in the corner from either the front or the side. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
25 replies so far
#1 posted 187 days ago |
It doesn’t handle thicker woods, but this is my favorite tool for that. -- There is little that is simple when it comes to making a simple box. |
#2 posted 187 days ago |
My Stanley Dowelling Jig. Nothing better IMHO. Cheers! -- Dave; Lansing, Kansas |
#3 posted 187 days ago |
I’ve used one like this for 20years. I think they can be found much cheaper though. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 187 days ago |
I thought about one of those Don, but the holes I need to drill on on a corner so I need something hand held or that I can clamp on, even though a clamp gets in the way of at least one hole making it twice the job it should be. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#5 posted 187 days ago |
That is why I like the jig I posted Russ. It clamps both boards at the same time and misalignment in tricky places is virtually impossible. -- There is little that is simple when it comes to making a simple box. |
#6 posted 187 days ago |
If you need flush corners in 3/4” stock for cabinets I have the Jessem and while it is kind of slow going Lots of jigs can do a decent job with frames but |
#7 posted 187 days ago |
David, here is the application I need it for and why I don’t think it’s the right one. I need a jig that can get me three dowels into the corner coming from the front or the side. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#8 posted 187 days ago |
Loren, Ideally I’d love to see a corner clamp that has doweling jigs built in. Wouldn’t that be a cool thing? -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#9 posted 186 days ago |
Why not just make a custom block out of scrap hardwood? Drill it out straight on a drill press. Then add a fence for the appropriate setback. Clamp it on with bar or pipe clamps. Cheers! -- Dave; Lansing, Kansas |
#10 posted 186 days ago |
The guide can be used for 90 degree joints as well as T joints. It is pretty versatile. -- There is little that is simple when it comes to making a simple box. |
#11 posted 184 days ago |
Make a jig from any wood, even a 2×4. Drill the holes in a drill press. size will be to accomodate hardened steel drill bushings for the drill size you want to use. http://www.mcmaster.com/#cadinlnord/8492a242/=klvox0 |
#12 posted 184 days ago |
Russel- I have used Firehouse’s method and it works great! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
#13 posted 184 days ago |
Are you trying to put dowels in to an existing piece from Doweling frames is one thing, but doweling panels If you want to dowel with flush corners within .5mm tolerances I may not know something though…. perhaps there is a |
#14 posted 183 days ago |
You say you can wait until after the glue dries and then put dowels in from the outside – so why couldn’t you just drill through the face of one panel into the edge of the other, apply glue to the hole and the dowel, and drive it in – no jig necessary? You’d only need something to make sure the drill goes in squarely. Or am I not understanding? -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#15 posted 183 days ago |
This is where only $ increases performance. The cheap dowel jigs work but the expensive ones do so much better and at places where the cheap ones won’t fit. -- Never board, always knotty, lots of growth rings |
| Forum | Topics |
Woodworking Skill Share
8842 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
68 |
Joinery
96 |
Finishing
1597 |
3591 |
15972 |
Hand Tools
2093 |
Jigs & Fixtures
501 |
Wood & Lumber
2905 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2772 |
LumberJocks.com Site Feedback
1551 |
Coffee Lounge
6130 |
