Being frank about finishes
Forum topic by RussellAP posted 162 days ago 628 views 1 time favorited 11 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 457 days
162 days ago
One of my friends here on LJ is Charles Neil, he’s a pro finisher and I would trust him with any finish question I have and follow it to the letter. Lately I’ve come to understand that finishing is just as much an art as design.
We all know that no matter how well you build a piece, you can kill it with the wrong finish. And it’s one thing to be good with building things and quite another to be talented at finishing. You have to throw yourself AT the problem, not run away from it.
Finishing is the last thing you do to a piece, but it’s the first thing you should think about when planning a project.
It will affect your wood choice, your intended use choice, and even the design choices you make. Finishing isn’t that nasty necessary thing you do after you build something.
How many of you take finish into account before you even decide on the wood you buy for a project? Or do you wait till later and deal with the situation as it is?
I think we all have an ideal for the finish we like to use, like satin, or polished oil, or shellac. If you’re satisfied, I’d stick with it, but I’d also encourage you to try other things. Gel-Coats, Water based, Dyes. Did you know that some wood looks great blue?
So tell us about your finishing habit/rituals especially the tricks you’ve picked up along the way.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
11 replies so far
View Jorge G.'s profile
Jorge G.
1313 posts in 645 days
#1 posted 162 days ago
There is really nothing more to post as you stated all the reason. I start by choosing the finish I plan to use (shellac, poly, lacquer, etc.) Then choose the wood because of it’s appearance and how I am going to glue it together and then follow the design.
-- Just because you’ve always done it that way doesn’t mean it’s not incredibly stupid.
View waho6o9's profile
waho6o9
2911 posts in 747 days
#2 posted 162 days ago
One thing to consider is to finish the project after a dry glue up.
Tape off the areas that need glue, seal up and finish your project,
and then glue up your project.
Good thread Russell.
View Ripthorn's profile
Ripthorn
490 posts in 1155 days
#3 posted 162 days ago
For me wood choice and finish choice are pretty much simultaneous. I don’t think “I want to use this finish, so what wood will go nice with it?”, as I think that is as much a problem as choosing wood first and then finish later. It is the combination that I take into consideration. I mostly build guitars, so I have done the dyes, stains, ebonizing, etc. and agree that there’s nothing wrong with doing stuff like that. I like working with shellac, water-based lacquer, solvent lacquers, wipe on varnish, etc., but have recently found that I hate polycrylic (just had to sand it off of nine smaller pieces last night, ugh).
In short, I try to visualize the whole project before buying any materials. Finish is a very big part of it. My main goal is to make projects that just ask to be touched and that deliver when they are. Now, that doesn’t mean I’m very good at it :)
RussellAP
#4 posted 162 days ago
Waho6o9, yes, thick and thin masking tape is a must.
View Cosmicsniper's profile
Cosmicsniper
2148 posts in 1329 days
#5 posted 162 days ago
That’s always how you should start a project.
Once I realized this, and became really tired of being confused all the time about finishing, I bought every book on the subject and I setup a laboratory for experimentation. There are still some types of products that I lack experience with, but because I now understand what they are in theory, I have an insight into how those products will behave once I use them.
To me, that’s the key “trick”...become a student on finishing. Research it. Go to school.
The only other trick I can give is to make dewaxed shellac a part of your routine. It really is a universal product, whereas you can remove a lot of the compatibility issues and concerns you might have regarding finishing.
-- jay, www.allaboutastro.com
RussellAP
#6 posted 162 days ago
Jay, I have several packages of shellac. I may try it. My sign post out front had one coat and it’s holding up well.
waho6o9
#7 posted 162 days ago
I’ve never used shellac, but from what I’ve read dewaxed shellac
is the way to go. I should try some.
French polish is another system that I like the results from, that
mirror like look totally rocks. It seems complicated at first, but I think
once you get in down it will be easy.
View lumberjoe's profile
lumberjoe
2400 posts in 418 days
#8 posted 162 days ago
I finish my pieces before I start. Unlike a lot of people, finishing is my favorite part of the project. I do start off with a wood species though; not a finish. After I have lumber rough dimensioned I do cut off a few pretty nice looking sections to test finish on. I don’t just do a quick test. I will finish the scraps as I were finishing the piece – multiple coats with sanding in between, if I am using oil/stain under the finish, blotch controllers, waxes, etc.
I also pre-finish my work. The results are SO much better. I tape off the areas that will get glue. Glue won’t stick to finish so it cleans up really easy and you don’t have to worry about contamination or extra sanding. Once the piece is assembled, I will apply a final coat of finish, buff it out and wax it (if I am doing so)
-- http://www.etsy.com/shop/KandJWoodCrafts
Cosmicsniper
#9 posted 162 days ago
If those packages are flakes, Russell, you’ll want to let them settle after you mix them. This will let the wax drop to the bottom and you can separate it out.
There are certainly applications for waxed shellac as a film finish, but I’m talking about using dewaxed shellac (I like Zinsser Sealcoat in the can) as a bridge between oils/stains and film finishes. I even use the stuff to deliver color (as a toner) by using TransTint dyes with the shellac. I like the control it gives by sneaking up on result. This is especially useful when trying to color diverse woods to make the finish more uniform, which is something you can’t do just by staining the raw wood.
View Henry6's profile
Henry6
13 posts in 197 days
#10 posted 72 days ago
My favorite part about finishes is that each type of wood can be transformed in many different ways based on which finish you choose. I remember doing my deck a few months back, and my wife and I were stuck deciding between a transparent or semi-transparent finish from Storm System. Unlike paint, it was easy to see how both looked before deciding.
View Monte Pittman's profile
Monte Pittman
7069 posts in 508 days
#11 posted 72 days ago
I am now doing different finishes. Learning more as I go.
-- Mother Nature created it, I just assemble it. - It's not ability that we often lack, but the patience to use our ability
