Holding strength of pocket hole joinery
Forum topic by pingpingpang posted 12-12-2012 08:04 AM 3426 views 0 times favorited 18 replies Add to Favorites Watch
View pingpingpang's profile
pingpingpang
12 posts in 1896 days
12-12-2012 08:04 AM
I’m planning on doing a project that will involve using pocket hole joinery to connect a sheet of 3/4 Oak plywood to 1×4 Oak boards (as stair tread edge) for stair treads. Those stair treads will be connected on top of the old treads by liquid nail. I am just wondering if pocket hole joinery has enough holding strength. Or I just have a bad idea.
Thanks
18 replies so far
View Monte Pittman's profile
Monte Pittman
28157 posts in 2242 days
#1 posted 12-12-2012 09:57 AM
Should work. Don’t be cheap with number of screws used though.
-- Mother Nature created it, I just assemble it.
View bluekingfisher's profile
bluekingfisher
1247 posts in 2883 days
#2 posted 12-12-2012 10:02 AM
You may have issue with the overall rise of the tread. I looked into doing exactly that but was advised the additional rise created by the thickness of the new boards could create a trip hazard. Perhaps those providing the information were being a little over cautious, however they were building professionals.
Perhaps you should seek guidance on this…..just a thought!
-- No one plans to fail, they just, just fail to plan
Rick Dennington
5693 posts in 3098 days
#3 posted 12-12-2012 02:12 PM
View crank49's profile
crank49
4029 posts in 2875 days
#4 posted 12-12-2012 03:03 PM
If you add 3/4” to the top of every step there is no increase in the rise except the first and last treads will have more or less rise than all the others. All the rest of the steps are the same relative to each other.
Building code usually requires no more than a 1/4” difference in any step within a stair. It can be made stricter by local codes.
I have been living in my house for 36 years and just discovered a couple years ago that the steps between my great room and the rest of the house are almost 1” different from top to bottom in both rise and run. Never knew it till I went to replace carpeted steps with hardwood and had to cut new risers and treads. I think the trip hazard must be over rated.
View Earlextech's profile
Earlextech
1160 posts in 2594 days
#5 posted 12-12-2012 04:23 PM
Pocket hole joinery with glue is plenty strong for that situation.
116902 posts in 3481 days
#6 posted 12-12-2012 04:33 PM
ditto Earlextech’s
View Loren's profile
9941 posts in 3552 days
#7 posted 12-12-2012 05:04 PM
If I am visualizing this well, you’d be driving pocket screws
into the back side of the plywood with the points coming
through and pointed at the flush corner of the solid oak
lipping. There won’t be a lot of material there to shape
without running into screw ends.
Gluing alone is sufficiently strong, but nails or countersunk
and plugged screws through the front edge allow one
to forgo a lot of work with clamps.
I would not do it with pocket screws, personally.
pingpingpang
#8 posted 12-12-2012 05:12 PM
Thanks for all replies.
Basically I want to put two pieces wood together by using kreg pocket hole jig and glue in order to get a stair tread. The edge of a stair will be 3.5 inch oak.
And Building code is now my concern.
#9 posted 12-12-2012 05:25 PM
The veneer on ply is very thin and not rated for
flooring and will not hold up.
pingpingpang
#10 posted 12-12-2012 05:33 PM
Loren,
You are right. I may need to change my plan
View DS's profile
DS
2855 posts in 2324 days
#11 posted 12-12-2012 05:36 PM
Also, keep in mind that most fasteners are only there to hold things until the glue dries.
Glue isn’t typically an optional accessory. (Just don’t tell some of those production guys.)
View MrRon's profile
MrRon
4628 posts in 3147 days
#12 posted 12-12-2012 10:45 PM
I would not use oak plywood or any plywood for that matter. The veneer on the plywood is much too thin to stand up to foot traffic.
View Mark Smith's profile
Mark Smith
509 posts in 1944 days
#13 posted 12-12-2012 10:51 PM
Good catch Loren, I wasn’t even thinking of that either, but you are right.
404 - Not Found
2544 posts in 2873 days
#14 posted 12-12-2012 11:01 PM
Could you not use some semi solid flooring instead for the treads?
Just on the pocket screws, I recently ‘dismantled’ an early bookcase I made which was put together with pocket screws. It took some full on blows with 20oz Estwing to take apart and the material broke before the joints did in a couple of places, if that gives you an idea of their strength.
pingpingpang
#15 posted 12-12-2012 11:11 PM
I will use my solid flooring for wood treads.
