A shot in the dark, need parts for a grizzly Slow-Speed Grinder
Forum topic by Don W posted 12-11-2012 10:24 PM 1598 views 0 times favorited 8 replies Add to Favorites Watch
View Don W's profile
Don W
19050 posts in 2807 days
12-11-2012 10:24 PM
Ok this is a shot in the dark, but I bought a Grizzly G1036 Slow-Speed Grinder from a fellow LJ. USPS promptly trashed it in route. The LJ was nice enough to work out a deal that I hope he felt was amicable to both of use and I do have it working. The parts that are broke are not sold individually so I’m hoping somebody would have one that’s not working and would have the parts they would sell. I need the switch and motor enclosures.
I can buy the whole new motor, but that’s $80.
Nothing wrong with duct tape (probably should get some black) but I wouldn’t mind fixing it right.
8 replies so far
View BTKS's profile
BTKS
1989 posts in 3704 days
#1 posted 12-12-2012 02:35 AM
Good luck, looks like USPS did a bang up job kicking the S—- out of it!
Ain’t duct tap a wonderful thing.
-- "Man's ingenuity has outrun his intelligence" (Joseph Wood Krutch)
View bluekingfisher's profile
bluekingfisher
1311 posts in 3219 days
#2 posted 12-12-2012 08:58 AM
Don – I don’t have the parts however, from looking at your craked casing have you considerd using plumbers PVC pipe weld? You know, the stuff which comes in a tub with an included applicator brush.
I used it to “weld” the cut line when making reducer pipes for my dust collection system. The stuff holds up really well, the pipe is under a great deal of pressure but holds OK. Just run a bead of the solution along both edges of the broken casing and hold it in place with pipe clamps or band clamps. It sets in about 10 – 15 seconds so being quick and nimble is the key.
Make sure to slightly sand the mating surfaces before hand to create a key for the glue.
Good luck.
David
-- No one plans to fail, they just, just fail to plan
View paratrooper34's profile
paratrooper34
915 posts in 3191 days
#3 posted 12-12-2012 11:00 AM
Don, that looks pretty bad. I just cannot believe that jackasses treat someone else’s property so poorly. If this is a sample of how the USPS does business, it doesn’t seem so far of a stretch that they take massive losses year in and year out.
Be careful using that plumber’s glue. It requires a companion primer for proper sealing and it doesn’t work on all plastics.
PS: it was amicable. Sorry you got it in that shape.
-- Mike
bluekingfisher
#4 posted 12-12-2012 11:42 AM
Para – No, the plumbers glue does not require a companion. It is simply smeared onto the inside of the PVC pipe and onto the corresponding male pipe. Time is money if you are a plumber and the need for introducing extra additives is not an option.
Usual rules apply, test on a smal piece first, certainly holds tight on my plastics.
Don W
#5 posted 12-12-2012 12:55 PM
thanks guys. I have no plans to take it apart again unless I get the right parts. The glue may work for the main housing, but there are to many parts missing from the switch box.
I’ll keep searching and just use it as it is for now.
View Dave's profile
Dave
11429 posts in 3079 days
#6 posted 12-13-2012 12:42 AM
Duck Tape Don. Sorry I dont have any parts but I will keep an eye out.
paratrooper34
#7 posted 12-13-2012 12:50 AM
Bluekingfisher, there is a companion, it is called “primer”. Some state plumbing codes have it written into their verbage; others still require primer to be purple in color to prove its use. Google it, I am sure you will find it somewhere.
I was a licensed plumber in a previous life.
-- Mike
View OnlyJustME's profile
OnlyJustME
1562 posts in 2616 days
#8 posted 12-15-2012 12:47 AM
Could use Plastruct Plastic weld or Ambroid Pro Weld instead of the pvc stuff. It works on many if not most plastics and does not need a primer. Available in hobby and some hardware stores. But that’s if the duct tape ever fails which if the motor gets hot enough it might.
-- In the end, when your life flashes before your eyes, will you like what you see?
