Shoving Jewels in Your Crotch
Forum topic by RussellAP posted 163 days ago 755 views 0 times favorited 13 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
2394 posts in 457 days
163 days ago
I saw where a guy, (turns out lots of guys) are using crushed up turquoise to fill imperfections in wood.
I HAD to try this.
My first victim…...walnut slab with crotch void.
It’s a messy process and the clear epoxy is not easy to work with nor be neat with. You may as well just give up and make a mess because you have to sand it down anyway.
Some of the deep voids let the turquoise drop down too far so that looks bad.
I have several choices for filler from blue metal, to gold metal, to agate, turquoise, different color sand.
I chose turquoise for my first try.
It looks ugly as hell while you’re doing it. I thought I ruined the wood several times.
Fortunately for me, I can place the clock on this to hide some of the more glaring problems with that large void.
I plan on giving this to my son for Christmas. I don’t think it’s something he’ll appreciate till some years pass, but I hope one day he will try his hand at woodworking.
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
13 replies so far
View Dave's profile
Dave
9195 posts in 1011 days
#1 posted 162 days ago
I have wanted to try this as well. Thanks for the tips. What was the cure time on the epoxy?
RussellAP
#2 posted 162 days ago
Dave, I waited about 20 hours. It was dry as a bone with a heater under the board.
87269 posts in 1748 days
#3 posted 162 days ago
Very cool Russ,great job.
RussellAP
#4 posted 162 days ago
Jim, filling the crotch was not as easy as I thought. Seems if the epoxy has any depth to it at all, the stones or shavings will sink to the bottom. I have some molding epoxy which is made for casts of things. I may try that because it will set up level quickly so I can add the stuff after it sets with some regular epoxy and prevent it from falling to the bottom.
I may try some brass shavings the next time around.
View redryder's profile
redryder
1590 posts in 1272 days
#5 posted 161 days ago
I am willing to try most anything and this is one of them.
I have always liked the look of turquoise jewelry etc.
I must admit that every photo of turquoise inlay in a piece of wood looks like more of a distraction than an asset.
I have seen many pix of this genre and wanted to keep an open mind but I have never seen one that looked good. Maybe I need to see it in the flesh…...................
-- mike...............
View RVroman's profile
RVroman
160 posts in 194 days
#6 posted 161 days ago
I have only tried this on turnings (see example below) and am not sure if the crushed stone powder is the same as you are using, but here is what I have found….
For shallow voids I fill with the powder, then use thin CA (medium also works) to set it place. For deeper voids I mix the powder and epoxy first, then fill the void. If it is deep enough I fill it in layers to allow for better drying, rather than filling all at once (the first time I did a deep void I did do it all at once, and 5 minute epoxy took about 24 hours, just as you found)
-- Robert --- making toothpicks one 3x3x12 blank at a time!
View Henry6's profile
Henry6
13 posts in 197 days
#7 posted 161 days ago
You found very nice thing to work on but don’t you think 24 hours for 5 minute epoxy is very long time…
View NiteWalker's profile
NiteWalker
1477 posts in 747 days
#8 posted 161 days ago
Thread title is full of win, but seriously, nice job.
I remember reading some articles on epoxy inlay a while back using some other stones/powders. Some nice things can be done.
RussellAP
#9 posted 161 days ago
Henry, it was an overnight and I couldn’t get to it till late the next day.
View AandCstyle's profile
AandCstyle
643 posts in 428 days
#10 posted 161 days ago
I haven’t used it, but InLace looks to be a similar product, and might be easier to use. FWIW
-- Art
NiteWalker
#11 posted 161 days ago
Art, that’s the stuff I read about a while back. Thanks for the link; added to my faves.
View okwoodshop's profile
okwoodshop
386 posts in 1346 days
#12 posted 161 days ago
Russell,just wanted to add my two cents worth. I use super glue and calcite. Calcite is a soft stone and comes in several colors and is very cheap, and available on the internet. You can use it to fill some very large voids as I did on this rocker head board. I left a large stone rough and hanging out at the bottom to give it a mined effect. I have also used coal if I need black and some shells crushed make good filler that can be sanded. Copper shavings, brass, and aluminum make little veins thru the stones to.The super glue is thin enough to soak in to punky wood and strengthen it.Just put the stone or other material in the void and dribble the glue over it. It will dry in about an hour. sand and use smaller crushed pieces till you have it filled the way you want.You may have to save this picture and enlarge it to see the stones good.
View Purrmaster's profile
Purrmaster
401 posts in 264 days
#13 posted 160 days ago
I love the title of this thread. Does the filler take stain at all?
