Which finish to use?
Forum topic by WudWrkr posted 98 days ago 92 views 0 times favorited 4 replies Add to Favorites
View WudWrkr's profile
WudWrkr
21 posts in 256 days
98 days ago
I need a little finishing advise and welcome any and all input. I have two projects that I want to stain, but I am not sure what finish coat to use.
The first project is a small decoratve red oak shelf. It is approx 24” long by 9” high (there is an oak back below the shelf). I made this from one piece of oak so the color of the raw wood matches pretty closely, I just want to darken it a little. The grain isn’t paticularly fancy so I don’t need to “pop” it.
The second project is a, mostly utilitarian, shelf made from some really clear, very white 5/8” plywood (I assume it is pine). Measures approx 46” x 24” with two sheets sandwiched together to give two nice surfaces. I will be edging this with soft maple (just because I have it lying around and it color matches pretty good.)
I probably got the cart in front of the horse on this one, but I’ve been wanting to try a gel stain so I bought a can of Minwax Antique Oak gel to use on both projects. I did this before giving a lot of thought to the finish coat. I prefer to use a wipe-on finish for the small shelf as it has several possibilities for runs if I use a brush. Wipe-on or brush-on would be fine for the large shelf as it is just two flat surfaces.
As I understand it from Bob Flexner’s book I could have the problem of picking up stain from the surfaces if I wipe or brush a finish (I should have read this before I got the gel!). Now I’m getting cold feet as to how to proceed. I need some LumberJock advice please- thanks.
-- Steve - "Dang, no matter how many times I run it through the planner it's still too thin!"
4577 posts in 754 days
98 days ago
I see no problem with trying out your gel stain on these projects. Just wipe it off well and don’t expect to darken the wood a whole lot on the first coat. On a dense wood, most of the stain will come off on your rag. I’d finish with a wipe-on ploly after the stain was good and dry. (Not still tacky)
WudWrkr
97 days ago
Thanks for the response Charlie. Would one of the MinWax polys thinned quite a bit be a good choice in your estimation?
97 days ago
They are pretty thin to begin with, Steve. I’m not sure why you would want to thin them. You might try the stain/poly process out on a scrap from the same wood so you’ll have a feel for how it will go on and how it will look.
WudWrkr
97 days ago
Yes, I’ll try it on scrap first. Thanks again Charlie.
Bookmark And Share This Page
