A question about cleaning hand tools. Ruined Bed Rock Plane?
« back to Hand Tools forum
Forum topic by walterdlewis posted 12-11-2012 09:20 AM 1047 views 0 times favorited 5 replies Add to Favorites Watch
View walterdlewis's profile
walterdlewis
4 posts in 1972 days
12-11-2012 09:20 AM
Topic tags/keywords: hand tools cleaning bed rock acid
I feel like a fool even posting this, but I might have ruined my Bed Rock 605.
I have used Muriatic acid to clean files and such for a while, but now I may have made a mistake. This morning I was cleaning some files, and decided to throw in my Bed Rock Jack Plane body in to see if I could get some of the persistant rust off the sides. the acid was about an inch deep, and I put it in and moved it around a bit to get good coverage. I kept it in for about 10 minutes, and when I took it out and rinsed it the finish was dull, almost like I Parkerized it. Now I am trying to brighten things back up by lapping the plane. I heard that the acid starts a chemical reaction that dosent stop, and will make parts rust much more readily. Did I ruin it? Any advice on how to un-ring the bell?
5 replies so far
View David Craig's profile
David Craig
2137 posts in 3017 days
#1 posted 12-11-2012 10:12 AM
I can’t speak from experience with this acid, just foggy memories from chemical class. Acids and Bases neutralize each other. Perhaps a quick bath in baking soda?
View StumpyNubs's profile
StumpyNubs
7538 posts in 2709 days
#2 posted 12-11-2012 02:39 PM
Cast iron is a lot softer than your files. Use Evaporust next time. You may have dulled it, but not ruined it. Give it a good long baking soda bath. It’ll be fine.
-- Subscribe to "Stumpy Nubs Woodworking Journal"- One of the crafts' most unique publications: http://www.stumpynubs.com/
walterdlewis
#3 posted 12-11-2012 02:46 PM
Thanks for the replies guys. I soaked it in a strong baking soda/water solution, once I polished off the odd grey parkerized kind of look it seemed to clean up fine.
View Dave's profile
Dave
11426 posts in 2748 days
#4 posted 12-13-2012 02:16 AM
Good luck. Electrolysis is another good noninvasive method.
View exelectrician's profile
exelectrician
2327 posts in 2335 days
#5 posted 12-14-2012 08:41 AM
I am thinking that acid would attack the sharpest points on any surface so when you put files in acid that would instantly dull the file. Or am I being wrong in my thinking here?
-- Love thy neighbour as thyself
