drying time of shellac before packaging for shipment?
Forum topic by JesseTutt posted 12-10-2012 11:43 PM 904 views 0 times favorited 4 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2074 days
12-10-2012 11:43 PM
Topic tags/keywords: question shellac dry time
I have been (and still are) sick. This put me behind in my woodworking projects for Christmas. I was planning on finishing cedar with a single coat of 2lb shellac, let it dry and then wrap it in bubble pack and ship them.
If I finish in my 65-70 degree basement, is overnight sufficient before I wrap it in packing? If not how long?
117061 posts in 3541 days
#1 posted 12-10-2012 11:54 PM
If your shellac is fresh it should be dry in an hour or less.
View John's profile
John
47 posts in 2037 days
#2 posted 12-11-2012 06:58 AM
I agree… as long as that “single coat” isn’t too thick it will dry very quickly. If you want to be sure, but you need a little more finish build, you might pad on a couple of very thin coats.
View Purrmaster's profile
Purrmaster
915 posts in 2057 days
#3 posted 12-15-2012 04:04 AM
In a temperature like that overnight should be fine. It might harden up a bit more in a day or two but I think the piece will be fine. One of the best things about shellac is that it dries so fast. I can even get it to dry in the cold winter temperatures.
View Redoak49's profile
Redoak49
3193 posts in 1952 days
#4 posted 12-15-2012 02:47 PM
My experience is that it may take a day or so. It depends a lot on the cut and how old the can of shellac is. I find that older shellac takes longer to dry and is a bit thicker. This is probably because some of the alcohol comes off when the can is open.
I try to let things with Shellac dry in open air with a small fan blowing on it. I wait for the fan until the surface is dry enough that dust will not stick
