| Forum topic by Darkeyce | posted 164 days ago | 550 views | 0 times favorited | 15 replies | ![]() |
164 days ago |
Built a frame. My first one. It went “interestingly”.
15 replies so far
#1 posted 164 days ago |
Pare the back of the miters w/ a chisel so the surface comes together. -- Bondo Gaposis |
#2 posted 164 days ago |
The joint is already glued…Not sure how to make any changes without cutting the joint. After i looked at my setup further it looks like my saw was not exactly 90 deg. So the mitre faces are is slightly angled. Hence the gap. |
#3 posted 164 days ago |
It won’t help on this one, but the next one you may want to look into a shooting board if you have access to a decent hand plane. The other option, go ever so slight past 90 the opposite way. For this one you may be able to cut an inlay into the corners. In other words, make it look intentional with some kind of high light. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#4 posted 164 days ago |
Saw the joints open and redo. The frame will be only be slightly smaller. -- Bondo Gaposis |
#5 posted 164 days ago |
If it’s glued already take a thin piece wood with as close of a grain match as possible with a little glue (white is best) let dry and then use a sharp chisel an or a card spacer and then touch up the finish as necessary. The other guys ideas will work too. -- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com/ |
#6 posted 164 days ago |
does it look the same on the back-side? From my perspective it looks like a little “hollow” (funny what a 1/4 degree can do huh? especially when you aren’t using $25,000 laser saws) old finish carpenters used to use a matchbook cover to create a slight bevel so the gap would be on the backside and would be easier to trim on the front-side. professional picture framers use something akin to a big paper cutter. fix? try laying face down on a piece of clean soft material and tapping it…might open up the joint. go lightly. if that doesn’t work, then you will understand the concept of “filler”. |
#7 posted 164 days ago |
I appreciate all the ideas… I think I’m going to end up trying to either a) fill the gaps with thin pieces or cut a piece of purpleheart and use it as a “feature” piece overlaying the joint. I really wanted the Joints to show though, i like the change in grain. My final more drastic choice is to recut the joints as suggested and insert a 1/8 or 1/16 piece of purpleheart, that way i get a highlight, and the frame stays the same size and the color change will cover any issues with the joint. |
#8 posted 164 days ago |
great post darkeyce,i just had this problem myself.fortunately my customer was going to paint it and i don’t know if this was the correct or even a good fix but i used filler and sanded.it turned out great after that,my customer painted it and distressed it. marty. -- It don't have to be straight,it's just a suggestion!!! |
#9 posted 164 days ago |
How about cutting a square grove along the miter and then inlaying a darker piece of wood? You could cut the inlay channel with your table saw or router table using some type of jig. It will add some highlight to your frame too. -- Mark Smith, Tracy, CA., http://www.markscustomwoodcrafts.com |
#10 posted 164 days ago |
put a couple drops of glue on the joint and hit it with a sander. the sawdust from the sander will mix with the glue and fill the gap |
#11 posted 164 days ago |
Just remember to always do a dry-fit before assembly…That way you’ll know…. -- " Don't ever wrestle a pig in a mudhole....he'll be having more fun than you..!! |
#12 posted 163 days ago |
If you want to try sawing the joint apart, get a little razor saw (for want of a better name). These are extremely thin, and can have 20 or more very fine teeth per inch. You would lose very little wood that way. You might even find the saw would fit into the existing gap so marring the wood wouldn’t be a problem. My local hardware store has them—but then they have everything (Hardware Sales in Bellingham). You can probably get one off Rockler if you can’t find one locally. Oh, hobby shops are a good place to look, too. I have 3 or 4 of them, and use them quite often, sometimes in a situation much like you have. |
#13 posted 162 days ago |
Once again i appreciate all the suggestions. So this is what transpired next…. I reset my table saw to a little over 90 degrees so to address any top gap and using a sanding wheel i took a little of to smooth the new mitres. In a fit of efficiency (insert sarcasm), and haste, I pushed the inevitable accumulation of scraps and squares and clamps to the side and hastily reglued the joints. The next morning i realized i had glued the wrong pieces together…on the up side, the joints looked good. So i cut them apart again [giving up another 1/16” :( ], spent a few minutes and cleaned up my work space and went to bend. As i said to my wife, if it was easy it wouldn’t be any fun! anded the ends to |
#14 posted 162 days ago |
Welcome to the learning curve, and a belated welcome to LumberJocks. Maybe practice on some scrap first until you’re satisfied with all Assuming you used a table saw, a miter sled may come in handy. http://lumberjocks.com/projects/39096, from LJer, Kent Shepherd |
#15 posted 162 days ago |
As Waho609 stated the miter sled IS THE WAY TO GO! If you take your time to build this correctly, perfect miters are a snap. The only thing you have to remember is to cut mating pieces on opposite sides of the jig. You may also want to look into a flat gluing station. My bench is not perfect so I slap down a piece of 3/4 MDF with rails on two sides that are 90 degrees. I push my frame pieces into the corner giving me at least one known 90. The rest simply fall into place. -- Made in America, with American made tools....Shopsmith |
| Forum | Topics |
Woodworking Skill Share
8794 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
81 |
Finishing
1534 |
3552 |
15794 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2842 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
