Removing Ridges and/or Router Bit Suggestion
Forum topic by mattm posted 99 days ago 168 views 0 times favorited 5 replies Add to Favorites
View mattm's profile
mattm
21 posts in 183 days
99 days ago
Topic tags/keywords: question jig maple router sanding milling
Since these questions may be linked, I decided to make them a 2-for-1 topic.
Anyway, since I don’t currently have a planer, I built a planing jig for my router that is a lot like this one, except my router is screwed onto a double layer of metal strips instead of using metal rods:
http://www.woodzone.com/tips/planerjig.htm
To my surprise, this method actually seems to work fairly well. I move the router side to side over the board in a “cross cutting” fashion, instead of taking long passes from bottom to top, since it is easier to control that way. The problem is that this leaves a bunch of ridges on the board.
I have been sanding it by hand with 100 grit paper in a sanding block and then finishing up with a card scraper. This has made things flat and smooth, but no matter how hard or long I seem to sand the board, I can never quite get rid of some of the streaks or lines that are left-over from where the ridges used to be. This is with hard maple, if that matters.
So, I’m wondering if I need to just keep on sanding, or if I actually need something like a palm or random orbital sander to get the job done here. Or am I just stuck with these streaks?
Alternatively, is there a router bit that won’t leave these ridges? I’ve been using the straight bit that was included with my Triton router for this.
Thanks much for any insights.
4579 posts in 755 days
99 days ago
I don’t have any experience using a router planing jig, but I can tell you this much for sure: If those ridges aren’t going away, you aren’t sanding enough. A decent random orbit sander isn’t very expensive, and it will save you tons of time and elbow grease.
If you can feel the ridges with your fingertips before you atart sanding, I would start with 80 grit, then 150, and finally 220. If you prefer a card scraper to provise your final smoothing, that’s great. Just sand out those ridges first! Even with a power sander, it is easy to make the mistake of not spending enough time with your coarse grit.
View BeechPilotBarry's profile
BeechPilotBarry
410 posts in 239 days
99 days ago
Try a block plane before the sanding block.
-- - Real men read directions
View Roper's profile
Roper
410 posts in 249 days
99 days ago
you could also use a number 6 hand plane to get rid of the ridges then just sand as you are.
-- Roper - master of sawdust-
View ChicoWoodnut's profile
ChicoWoodnut
748 posts in 352 days
99 days ago
I have not used this technique so don’t take this as gospel but thinking through it you might check to see if the router is level on the jig. I seems to me that if one side of the bit is “tipped lower” than the other side you might experience the ridges you are describing.
Just a thought.
mattm
95 days ago
Excellent suggestions, thank you much. I shall have to give these techniques a shot and see how things turn out.
Bookmark And Share This Page
