If you need a strop
« back to Hand Tools forum
Forum topic by Tedstor posted 160 days ago 496 views 0 times favorited 10 replies Add to Favorites Watch
View Tedstor's profile
Tedstor
924 posts in 799 days
160 days ago
Topic tags/keywords: strop sharpening
I bought a piece of leather/strop off this ebay seller a few months back. The guy sells a few different versions at any given time, but I went with the 3×9”. I glued mine down to a piece of scrap maple. Nice, thick leather stock. I’d guess about 1/8” thick. I use mine all the time with some green buffing compound. Very happy with the results.
I realize a strop can be made with an old belt or other sources. But for under $10, I decided this was the easier route to take. Especially since this strop is big enough to accomodate a wider range of tools.
And FTR, I have zero affiliation with this seller other than my one purchase from him. I just found that the “perfect” strop (for me) was harder to find than I thought. So I’m pointing this source out to LJ as a public service. YMMV.
http://www.ebay.com/itm/121035090384?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
10 replies so far
View live4ever's profile
live4ever
981 posts in 1177 days
#1 posted 160 days ago
Thanks for the tip! I’m curious – the only thing I’ve ever used for a strop is MDF (with green buffing compound) and it’s very effective. Does leather work much better or is it just a preference thing to strop with a softer substrate?
Tedstor
#2 posted 160 days ago
Good question. I dunno if one is better than the other. I’m a bit of a traditionalist. I suppose that’s what makes me lean into the leather camp.
View waho6o9's profile
waho6o9
2887 posts in 743 days
#3 posted 160 days ago
It’s amazing how well stropping keeps a sharp edge
when you’re working.
Some folks like the smooth side of the leather while
others prefer the rough side.
Maybe the rough side holds more compound?
Good job on the strop Tedstor.
live4ever
#4 posted 160 days ago
I can see the leather being better in some respects because the angle of your stropping doesn’t matter as much due to the softness of the material…vs. dead flat MDF where if you’re freehanding, you have to make sure you’re right on the bevel or secondary bevel. I’ll just have to try it. :)
View Lee Barker's profile
Lee Barker
1884 posts in 1017 days
#5 posted 160 days ago
I have a lot to learn here.
My father shaved with a straight razor and always had two strops—one leather, two different kinds, two sides, and one was a heavy fabric. I’d liken it to fire hose fabric. I don’t recall his putting any compound on them, but the razor always got stropped by both materials before the shave began.
The technique was to draw the tool toward himself with the cutting edge trailing, the blade nearly parallel to the surface. It was a long stroke.
Kindly,
View schnable's profile
schnable
10 posts in 248 days
#6 posted 160 days ago
I also have purchased a strop from this seller. I was able to obtain a custom size and I also asked for (and recieved) some scrap pieces to glue to the end of my holdfasts and clamps. Highly recommended.
View wunderaa's profile
wunderaa
132 posts in 369 days
#7 posted 160 days ago
I recently purchased some leather off of amazon to place on my vice faces. With the extra I cut myself a strop. For $10, you get 2 square feet. The seller also has other sizes for reasonable prices.
http://www.amazon.com/gp/product/B003X3VZA0/ref=oh_details_o00_s00_i00
Tedstor
#8 posted 160 days ago
Wunder,
Have you found that leather to be adequately thick? Some of the reviewers seem to indicate it to be under 1/16”.
For all I know, that could be more than adequate. If so, I might order some. Leather is a good material to have on-hand.
wunderaa
#9 posted 160 days ago
The leather I got was just shy of 1/8”, but I can see how it may vary somewhat. Mine is also a bit of a rough surface (it’s not top-grain), but I actually prefer a rougher surface for a honing strop, as it allows for better charging. At $10, it’s worth a try IMHO.
View hhhopks's profile
hhhopks
546 posts in 544 days
#10 posted 160 days ago
I buy my scrap leather from Hobby Lobby with their weekly 40% off coupon.
You will have enough leather for 10-20 stropes.
-- I'll be a woodworker when I grow up. HHHOPKS
